• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4-b144
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
Dear All,
i have been looking into this problem for some time now.
Past reference here:
https://forums.developer.nvidia.com/t/jetson-nano-crashes-after-3-to-10-days-of-operations/230912/1
Problem: after a certain amount of hours with the system running, the Jetson Nano just hang-up without any life signal.
As suggested by @linuxdev I have setup a serial console continuously logging the kernel log on a separate device.
I have been logging the behavior of Jetson Nano for weeks now, and lately I got this message:
[20:49:54.662037 0.187796] [13696.763832] blk_update_request: I/O error, dev sda, sector 388862096
[20:49:54.729131 0.067092] [13696.770270] EXT4-fs warning (device sda1): ext4_end_bio:313: I/O error -5 writing to inode 11409300 (offset 9515008 size 192512 starting block 48607810)
[20:49:54.839780 0.110651] [13696.783973] Buffer I/O error on device sda1, logical block 48607506
[20:49:54.927229 0.087445] [13696.790311] Buffer I/O error on device sda1, logical block 48607507
[20:49:54.991904 0.064680] [13696.797228] Buffer I/O error on device sda1, logical block 48607508
[20:49:55.036680 0.044775] [13696.803603] Buffer I/O error on device sda1, logical block 48607509
[20:49:55.081015 0.044336] [13696.809897] Buffer I/O error on device sda1, logical block 48607510
[20:49:55.136984 0.055968] [13696.816218] Buffer I/O error on device sda1, logical block 48607511
[20:49:55.181459 0.044474] [13696.822530] Buffer I/O error on device sda1, logical block 48607512
[20:49:55.231958 0.050500] [13696.828865] Buffer I/O error on device sda1, logical block 48607513
[20:49:55.276356 0.044397] [13696.835165] Buffer I/O error on device sda1, logical block 48607514
[20:49:55.320482 0.044128] [13696.841461] Buffer I/O error on device sda1, logical block 48607515
[20:49:55.367289 0.046805] [13696.847907] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.413999 0.046712] [13696.853190] blk_update_request: I/O error, dev sda, sector 231106960
[20:49:55.458451 0.044451] [13696.859551] Aborting journal on device sda1-8.
[20:49:55.489571 0.031121] [13696.859816] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.526986 0.037414] [13696.859851] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.563795 0.036810] [13696.859876] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.600220 0.036424] [13696.879723] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.645770 0.045551] [13696.884970] JBD2: Error -5 detected when updating journal superblock for sda1-8.
[20:49:55.698504 0.052733] [13696.892994] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.737519 0.039015] [13696.898288] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.774172 0.036653] [13696.905886] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.810654 0.036482] [13696.911160] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.847562 0.036904] [13696.916525] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.890523 0.042965] [13696.921814] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.927643 0.037120] [13696.927210] sd 0:0:0:0: rejecting I/O to offline device
[20:49:55.967215 0.039572] [13696.933031] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.004190 0.036976] [13696.961045] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.041395 0.037203] [13696.966364] EXT4-fs error (device sda1): ext4_find_entry:1441: inode #11406967: comm systemd: reading directory lblock 0
[20:49:56.118189 0.076796] [13696.977263] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.155175 0.036987] [13696.991878] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.191654 0.036477] [13697.151752] EXT4-fs (sda1): previous I/O error to superblock detected
[20:49:56.238201 0.046548] [13697.152823] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.275002 0.036801] [13697.163532] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.311506 0.036504] [13697.168776] EXT4-fs error (device sda1): ext4_journal_check_start:56: Detected aborted journal
[20:49:56.378052 0.066544] [13697.177393] EXT4-fs (sda1): Remounting filesystem read-only
[20:49:56.417703 0.039652] [13697.183021] EXT4-fs (sda1): previous I/O error to superblock detected
[20:49:56.463090 0.045388] [13697.189481] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.500068 0.036977] [13697.197253] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.537074 0.037007] [13697.202560] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.580377 0.043302] [13697.210772] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.617541 0.037164] [13697.216694] EXT4-fs error (device sda1): ext4_find_entry:1441: inode #661941: comm (start.sh): reading directory lblock 0
[20:49:56.695350 0.077809] [13697.228164] EXT4-fs (sda1): previous I/O error to superblock detected
[20:49:56.741109 0.045759] [13697.234990] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.777717 0.036609] [13697.401042] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.814610 0.036892] [13697.406341] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.851842 0.037231] [13697.650987] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.891097 0.039256] [13697.656293] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.928077 0.036977] [13697.900992] sd 0:0:0:0: rejecting I/O to offline device
[20:49:56.964913 0.036840] [13697.906292] sd 0:0:0:0: rejecting I/O to offline device
[20:49:57.001444 0.036531] [13698.151151] sd 0:0:0:0: rejecting I/O to offline device
[20:52:01.595446 124.593999] [13823.874271] sd 0:0:0:0: rejecting I/O to offline device
[20:52:01.664587 0.069142] [13823.879596] sd 0:0:0:0: rejecting I/O to offline device
[20:52:01.708125 0.043539] [13823.885126] sd 0:0:0:0: rejecting I/O to offline device
[20:52:01.744864 0.036740] [13823.890424] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.362951 0.618081] [13824.641577] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.459365 0.096351] [13824.646834] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.543726 0.084370] [13824.652107] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.653080 0.109350] [13824.657355] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.774847 0.121774] [13824.662606] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.831484 0.056693] [13824.667846] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.872463 0.040978] [13824.673206] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.924369 0.051908] [13824.678507] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.960816 0.036447] [13824.683763] sd 0:0:0:0: rejecting I/O to offline device
[20:52:02.997673 0.036856] [13824.689007] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.034524 0.036851] [13824.698270] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.072715 0.038191] [13824.703880] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.109458 0.036744] [13824.713690] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.146098 0.036639] [13824.722746] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.182899 0.036801] [13824.722803] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.220501 0.037602] [13824.729890] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.257132 0.036631] [13824.731424] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.294017 0.036886] [13824.740910] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.330460 0.036443] [13824.744429] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.370139 0.039679] [13824.744463] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.406781 0.036642] [13824.744473] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.444479 0.037697] [13824.744488] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.481417 0.036938] [13824.744712] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.518415 0.036999] [13824.744730] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.555077 0.036661] [13824.744803] sd 0:0:0:0: rejecting I/O to offline device
[20:52:03.591739 0.036662] [13824.745036] sd 0:0:0:0: rejecting I/O to offline device
I am currently booting the system from a USB3 SSD drive as explained here:
Do you think a disk change would solve the problem?
(I have already tried to change the sata-to-USB3 adapter without solving the issue apparently)
Thanks a lot!
