I need help with my jetson nano
Then back to previous comment as @fchkjwlsq said, did you see anything from usb-uart cable when your flash failure happened?
Also, are you sure your setup for this cable is correct? I mean did you see anything from this console after you bought the cable so far?
I made a wire cable using micro USB cable and a jumper wire and made it out of myself . And when i try to recover for the first time it worked then i removed the pins and i power-off the jetson and turn it again using the power adapter it didn’t work it just remain as black screen and the jetson’s light was on . I waited for few minutes it didn’t work then i put in recovery mode again and flash it again it came and then i restart using the power adapter again it gave me the same result then the third time i tried to flash again then i got error at flashing the jetson
These were the following error i got that i have filtered out from sdkmanager
09:55:23 SUMMARY: CUDA on Host - host: Install completed successfully.
09:55:23 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
09:55:23 SUMMARY: VisionWorks on Host - host: Install completed successfully.
09:55:23 SUMMARY: VPI on Host - host: Install completed successfully.
09:55:23 SUMMARY: Nsight Graphics - host: Install completed successfully.
09:55:23 SUMMARY: Nsight Systems - host: Install completed successfully.
09:55:23 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
09:55:23 SUMMARY: File System and OS - target_image: Install completed successfully.
09:55:47 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(401)
09:55:48 ERROR: Flash Jetson Nano - flash: /home/varun/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 2661: [: : integer expression expected
09:56:40 ERROR: Flash Jetson Nano - flash: 1+0 records in
09:56:40 ERROR: Flash Jetson Nano - flash: 1+0 records out
09:56:40 ERROR: Flash Jetson Nano - flash: 1 byte copied, 3.6627e-05 s, 27.3 kB/s
09:56:40 ERROR: Flash Jetson Nano - flash: 1 byte copied, 3.6001e-05 s, 27.8 kB/s
09:56:40 ERROR: Flash Jetson Nano - flash: 4+0 records in
09:56:40 ERROR: Flash Jetson Nano - flash: 4+0 records out
09:56:40 ERROR: Flash Jetson Nano - flash: 4 bytes copied, 4.0669e-05 s, 98.4 kB/s
09:56:41 ERROR: Flash Jetson Nano - flash: Error: Return value 8
09:56:41 ERROR: Flash Jetson Nano - flash: Failed flashing t210ref.
09:56:41 ERROR: Flash Jetson Nano - flash: *** ERROR: flashing failed.
09:56:41 ERROR: Flash Jetson Nano - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.varun.sh; [error]: *** ERROR: flashing failed.
09:56:41 ERROR: Flash Jetson Nano - flash: command terminated with error
09:56:41 SUMMARY: Flash Jetson Nano - flash: First Error: Installation failed.
09:56:41 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
09:56:41 SUMMARY: Multimedia API - target: Depends on failed component
09:56:41 SUMMARY: TensorRT on Target - target: Depends on failed component
09:56:41 SUMMARY: VisionWorks on Target - target: Depends on failed component
09:56:41 SUMMARY: VPI on Target - target: Depends on failed component
09:56:41 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
09:56:41 SUMMARY: cuDNN on Target - target: Depends on failed component
09:56:41 SUMMARY: OpenCV on Target - target: Depends on failed component
09:56:41 SUMMARY: Nsight Systems CLI - target: Depends on failed component
09:56:41 SUMMARY: DeepStream - target: Depends on failed component
09:56:41 SUMMARY: DateTime Target Setup - target: Depends on failed component
10:03:54 SUMMARY: CUDA on Host - host: Install completed successfully.
10:03:54 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
10:03:54 SUMMARY: VisionWorks on Host - host: Install completed successfully.
10:03:54 SUMMARY: VPI on Host - host: Install completed successfully.
10:03:54 SUMMARY: Nsight Graphics - host: Install completed successfully.
10:03:54 SUMMARY: Nsight Systems - host: Install completed successfully.
10:04:03 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
10:04:30 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
10:09:04 SUMMARY: File System and OS - target_image: Install completed successfully.
10:09:29 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(401)
10:09:30 ERROR: Flash Jetson Nano - flash: /home/varun/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 2661: [: : integer expression expected
10:10:28 ERROR: Flash Jetson Nano - flash: 1+0 records in
10:10:28 ERROR: Flash Jetson Nano - flash: 1+0 records out
10:10:28 ERROR: Flash Jetson Nano - flash: 1 byte copied, 4.1336e-05 s, 24.2 kB/s
And this is the error file
SDKM_logs_JetPack_4.6.4_Linux_for_Jetson_Nano_modules_2024-01-06_09-55-19.zip (181.6 KB)
And now i literally i have no idea how to solve it, help me asap
Just to make what I am asking clearly. I don’t care about your flash log from host right now.
You don’t need to post them. Especially you don’t need to post same thing twice… we already saw it and it didn’t provide much info unless combined with the device side log…
What I need to know is if you ever saw any log from the serial console before?
You don’t need to put the board in recovery mode. Even a power on will make the board print some logs (it may not boot completed, but logs will still come out).
If there is no log comes out, then maybe you should use other boards to check whether this cable is fine or not.
We require the log here to identify what is going on. There is nothing we can help unless you let it dump the log out.
If you cannot let it dump log out in the end, then please RMA this device and get a new one.
There is no log gets out it just stay blank screen
I mean power on the board. Not put the board in recovery mode.
BTW, are you sure you know what we are talking about here?
Could you share the command you are using to dump serial console?
I am not clear about this part “Could you share the command you are using to dump serial console?”
So you didn’t know what this comment is telling you to do at all?
I told you to buy an USB-UART cable. Use this cable to check the output of the Debug UART/UART #2.
yeah i removed the USB UART cable
… No, I am not asking you to remove usb-uart cable… I need you to connect it to dump the “serial console log” I told in previous comment.
What I was telling is to check whether cable is able to dump log out…
You need to follow this page and command to dump log …
[21515.991026] usb 1-2: new full-speed USB device number 113 using xhci_hcd
[21515.991267] usb 1-2: Device not responding to setup address.
[21516.199314] usb 1-2: Device not responding to setup address.
[21516.407075] usb 1-2: device not accepting address 113, error -71
[21516.535102] usb 1-2: new full-speed USB device number 114 using xhci_hcd
[21516.535309] usb 1-2: Device not responding to setup address.
[21516.743414] usb 1-2: Device not responding to setup address.
[21516.951227] usb 1-2: device not accepting address 114, error -71
[21516.951362] usb usb1-port2: unable to enumerate USB device
Got an error at dmesg --follow , here i am trying to get the path of the usb that jetson is connected i have connected to URAT TXD and RXD , Power and GND
Please try other cable… looks like the cable you are using has problem…
The cable is not the problem, Is there any other solutions
We are not providing a solution yet. We need you to dump the the log so that we can tell the next step.
If you cannot dump the log and cannot make the board flashed, maybe you could directly RMA your jetson and get a new one.
But if you hit same error next time, we still need you to reflash and dump log.
