• Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 4.6
• Docker base nvcr.io/nvidia/deepstream-l4t:6.0-base
• Docker opencv version 4.1
The pipeline connect to camera with RTSP stream using primary model, 2 secondary models, and tracker. The stream firstly been a while 0 FPS then start processing. The issue is when stream start to process their is set of FIX ME and WARNING issues appear. We try to change camera setting by reducing the (bit rate, … etc) but the same nothing change. Attached the output and configuration file.
start.ini (4.1 KB)
