How to stop displaying output video from deepstream python apps multi stream image data example
How to stop displaying output video from deepstream python apps multi stream image data example. I think it is consuming too much memory. Tried several approaches but no luck.
What kind of source are you using? Local video file or RTSP stream?
Currently I am using a local video but I am planing to use RTSP stream soon. But in either case, I don’t want an visual output on screen. I just want the app to run.
The app will stop when the local file is played to the end. Do you want to stop the pipeline when the memory consuming is larger than you expected? Or just you don’t want to show the video on the screen?
i want the app to run, i dont want the visual output. in python deepstream multistream imagedata example
Do you have experience of gstreamer app development?
You need to change the code. One way is to replace the following code with "sink = Gst.ElementFactory.make(“fakesink”, “nvvideo-renderer”) ":
sink = Gst.ElementFactory.make(“nveglglessink”, “nvvideo-renderer”)
i tried this approach and i got this error
0:00:08.671501246 12170 0x7fa45c2ed0 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:08.671554371 12170 0x7fa45c2ed0 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: streaming stopped, reason error (-5)
Error: gst-stream-error-quark: Internal data stream error. (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
@Fiona.Chen
I’ve tried it with deepstream-imagedata-multistream sample. It works. Just use fakesink is OK. Have you changed other things in the code?
This is my main function, I’ve only made the changes you mentioned @Fiona.Chen
def main(args):
    # Check input arguments
    print("mainnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn")
    if len(args) < 2:
        sys.stderr.write("usage: %s <uri1> [uri2] ... [uriN] <folder to save frames>\n" % args[0])
        sys.exit(1)
for i in range(0,len(args)-2):
    fps_streams["stream{0}".format(i)]=GETFPS(i)
number_sources=len(args)-2
global folder_name
folder_name=args[-1]
if path.exists(folder_name):
    sys.stderr.write("The output folder %s already exists. Please remove it first.\n" % folder_name)
    sys.exit(1)
os.mkdir(folder_name)
print("Frames will be saved in ",folder_name)
# Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
    sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
    sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
    os.mkdir(folder_name+"/stream_"+str(i))
    frame_count["stream_"+str(i)]=0
    saved_count["stream_"+str(i)]=0
    print("Creating source_bin ",i," \n ")
    uri_name=args[i+1]
    if uri_name.find("rtsp://") == 0 :
        is_live = True
    source_bin=create_source_bin(i, uri_name)
    if not source_bin:
        sys.stderr.write("Unable to create source bin \n")
    pipeline.add(source_bin)
    padname="sink_%u" %i
    sinkpad= streammux.get_request_pad(padname)
    if not sinkpad:
        sys.stderr.write("Unable to create sink pad bin \n")
    srcpad=source_bin.get_static_pad("src")
    if not srcpad:
        sys.stderr.write("Unable to create src pad bin \n")
    srcpad.link(sinkpad)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
    sys.stderr.write(" Unable to create pgie \n")
# Add nvvidconv1 and filter1 to convert the frames to RGBA
# which is easier to work with in Python.
print("Creating nvvidconv1 \n ")
nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
if not nvvidconv1:
    sys.stderr.write(" Unable to create nvvidconv1 \n")
print("Creating filter1 \n ")
caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
if not filter1:
    sys.stderr.write(" Unable to get the caps filter1 \n")
filter1.set_property("caps", caps1)
print("Creating tiler \n ")
tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
    sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
    sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
    sys.stderr.write(" Unable to create nvosd \n")
if(is_aarch64()):
    print("Creating transform \n ")
    transform=Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
    if not transform:
        sys.stderr.write(" Unable to create transform \n")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
if not sink:
    sys.stderr.write(" Unable to create egl sink \n")
if is_live:
    print("Atleast one of the sources is live")
    streammux.set_property('live-source', 1)
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
pgie.set_property('config-file-path', "dstest_imagedata_config.txt")
pgie_batch_size=pgie.get_property("batch-size")
if(pgie_batch_size != number_sources):
    print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
    pgie.set_property("batch-size",number_sources)
tiler_rows=int(math.sqrt(number_sources))
tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
tiler.set_property("rows",tiler_rows)
tiler.set_property("columns",tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("sync", 0)
if not is_aarch64():
    # Use CUDA unified memory in the pipeline so frames
    # can be easily accessed on CPU in Python.
    mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    streammux.set_property("nvbuf-memory-type", mem_type)
    nvvidconv.set_property("nvbuf-memory-type", mem_type)
    nvvidconv1.set_property("nvbuf-memory-type", mem_type)
    tiler.set_property("nvbuf-memory-type", mem_type)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(filter1)
pipeline.add(nvvidconv1)
pipeline.add(nvosd)
if is_aarch64():
    pipeline.add(transform)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(pgie)
pgie.link(nvvidconv1)
nvvidconv1.link(filter1)
filter1.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
if is_aarch64():
    nvosd.link(transform)
    transform.link(sink)
else:
    nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
tiler_sink_pad=tiler.get_static_pad("sink")
if not tiler_sink_pad:
    sys.stderr.write(" Unable to get src pad \n")
else:
    tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
# List the sources
print("Now playing...")
for i, source in enumerate(args[:-1]):
    if (i != 0):
        print(i, ": ", source)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
    loop.run()
except:
    pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
• DeepStream Version
• TensorRT Version
  1. Jetson
  2. Depstream 5.0
  3. Jetpack 4+
  4. TensorRT 7+
I see you are working on Jetson. So you need to the following change:
Remove the following codes:
if is_aarch64():
if is_aarch64():
else:
Add change the " nvosd.link(sink)" to “nvosd.link(sink)”.
“Add change the " nvosd.link(sink)” to “nvosd.link(sink)”." aren’t these same already? @Fiona.Chen
The space is different since there is no “if…else…” any longer.
okay, ill make the changes rn and let you know the results
Hello @Fiona.Chen, it worked the way i wanted. Thanks for the support. earlier i tried a similar approach but didn’t work. can you please tell me why only making a fakesink didn’t work?
Anyway, thanks for the help.
nvegltransform will create EglImage, this format can not be identified by fakesink or any normal gstreamer plugin.
okay, got it. is there a python implementation of back-to-back detector?
No.
can i create my own or python does not support secondary detectors?
