cd /lib/modules/4.9.140-tegra/kernel/net/can
sudo insmod can.ko
sudo insmod can-raw.ko
sudo insmod can-gw.ko
sudo insmod can-bcm.ko
cd /lib/modules/4.9.140-tegra/kernel/drivers/net/can
sudo insmod can-dev.ko
sudo insmod slcan.ko
sudo insmod vcan.ko
cd ./mttcan/native
sudo insmod mttcan.ko
hld@hld-desktop:~$ lsmod
Module Size Used by
mttcan 66187 0
vcan 3230 0
slcan 7266 0
can_dev 13306 1 mttcan
can_bcm 16471 0
can_gw 10919 0
can_raw 10388 0
can 46600 3 can_raw,can_bcm,can_gw
bnep 16562 2
fuse 103841 3
zram 26166 6
overlay 48691 0
bcmdhd 934274 0
cfg80211 589351 1 bcmdhd
nvgpu 1569917 37
bluedroid_pm 13912 0
ip_tables 19441 0
x_tables 28951 1 ip_tables
sudo ip link set can0 type can bitrate 500000
sudo ip link set can1 type can bitrate 500000
sudo ip link set up can0
sudo ip link set up can1
hld@hld-desktop:~$ ifconfig
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 131
can1: flags=193<UP,RUNNING,NOARP> mtu 16
device interrupt 132
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.108 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a05c:1930:7005:396b prefixlen 64 scopeid 0x20
ether 00:04:4b:de:3f:1b txqueuelen 1000 (Ethernet)
RX packets 1069 bytes 857673 (857.6 KB)
TX packets 1240 bytes 170430 (170.4 KB)
device interrupt 41
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 455 bytes 69570 (69.5 KB)
TX packets 455 bytes 69570 (69.5 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether de:fd:5f:cc:40:a1 txqueuelen 1000 (Ethernet)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether de:fd:5f:cc:40:a3 txqueuelen 1000 (Ethernet)
