How to test triton-inference-server with jmeter
Hi,all
I want to test HTTP server with jmeter. I know ip and port is ip:8000.
But if the model input is 24x24,model-name is yolov5. How should I write the message body data of the post request ?
Please specify details your use case.
Please specify more details, what do you mean " the message body data of the post request "?
When I send post request with jmeter, Input data is like this as follow:
“data” :
“INPUT0” : {“b64”: “YmFzZTY0IGRlY29kZXI=”},
“INPUT1” : {“b64”: “YmFzZTY0IGRlY29kZXI=”}
But the triton server told me:
Error Count:1
Data type (“text”|“bin”|“”):text
Response code:400
Response message:Bad Request
Is my Body data is wrong?
What is Apache JMeter?
Apache JMeter is pure Java-based open-source software designed to load test functional behavior and measure performance. You can use JMeter to analyze and measure the performance of web applications or a variety of services. JMeter was originally used for testing Web Applications or FTP applications. Nowadays, it is used for functional testing, database server testing, etc.
I am not sure Jmeter can be used to test triton inference server http or some others latency or throughput. you can refer to the link you provided for your purpose.
