hi, everyone, I am just new to Cuda.
I loaded the same image (pgm format )first by using Cuda function like below :
float * indata2 = (float*)malloc(640*480*sizeof(float));
unsigned int dataW2, dataH2;
CUT_SAFE_CALL(cutLoadPGMf("test.pgm", &indata2, &dataW2, &dataH2));
// show the image data (region: pixel x 200 to 205, pixel y 200 to 205 ) for camparing later
for (int y=200;y<205;y++) {
for (int x=200;x<205;x++)
printf("%.2f ", indata2[y*480+x]);
printf("\n");
result are :
0.67 0.65 0.66 0.65 0.65
0.40 0.38 0.34 0.35 0.47
0.31 0.31 0.31 0.32 0.30
0.26 0.58 0.82 0.75 0.35
0.67 0.67 0.66 0.66 0.64
then I load the same image by using openCV and show the imagedata for the same region. And the imagedata in openCV is saved in char format. see below :
typedef struct _IplImage
int nSize; /* sizeof(IplImage) */
int ID; /* version (=0)*/
int nChannels; /* Most of OpenCV functions support 1,2,3 or 4 channels */
int alphaChannel; /* ignored by OpenCV */
int depth; /* pixel depth in bits: IPL_DEPTH_8U, IPL_DEPTH_8S, IPL_DEPTH_16U,
IPL_DEPTH_16S, IPL_DEPTH_32S, IPL_DEPTH_32F and IPL_DEPTH_64F are supported */
char colorModel[4]; /* ignored by OpenCV */
char channelSeq[4]; /* ditto */
int dataOrder; /* 0 - interleaved color channels, 1 - separate color channels.
cvCreateImage can only create interleaved images */
int origin; /* 0 - top-left origin,
1 - bottom-left origin (Windows bitmaps style) */
int align; /* Alignment of image rows (4 or 8).
OpenCV ignores it and uses widthStep instead */
int width; /* image width in pixels */
int height; /* image height in pixels */
struct _IplROI *roi;/* image ROI. when it is not NULL, this specifies image region to process */
struct _IplImage *maskROI; /* must be NULL in OpenCV */
void *imageId; /* ditto */
struct _IplTileInfo *tileInfo; /* ditto */
int imageSize; /* image data size in bytes
(=image->height*image->widthStep
in case of interleaved data)*/
char *imageData; /* pointer to aligned image data */
int widthStep; /* size of aligned image row in bytes */
int BorderMode[4]; /* border completion mode, ignored by OpenCV */
int BorderConst[4]; /* ditto */
char *imageDataOrigin; /* pointer to a very origin of image data
(not necessarily aligned) -
it is needed for correct image deallocation */
IplImage;
IplImage* cvimg2 = cvLoadImage( "test.pgm", 1 );
// show the imagedata loaded by opencv (the same region 200 to 205)
printf("%d ", (uchar)(cvimg2->imageData[y*480+x]));
// here because the format of imagedata in openCV is char so transfer to uchar here
so it can be show from 0 to 255
printf("\n");
result are :
136 137 137 137 136
85 83 83 83 85
178 174 174 174 171
118 118 118 118 119
135 136 136 136 137
// transfer the char or uchar into float and them show the results
float * indata = (float*)malloc(640*480*sizeof(float));
for (int j=0;j<640*480;j++)
indata[j]=((float)((uchar)(cvimg2->imageData[j])))/255;
printf("%.2f ", indata[y*480+x]);
printf("\n");
result are :
0.53 0.54 0.54 0.54 0.53
0.33 0.33 0.33 0.33 0.33
0.70 0.68 0.68 0.68 0.67
0.46 0.46 0.46 0.46 0.47
0.53 0.53 0.53 0.53 0.54
BUT why are the results is different from the red one showed before ???
Why the imagedata in uchar 0 to 255 didn’t match the imagedata in float 0.0f to 1.0f ??
how to transfer the char or uchar imagedata to the matched imagedata in float format ? So that I can handle the image with Cuda further.
PLS help ME !
