Dear All,
I’m about to add some modifications to U-Boot on the Jetson Nano 2GB board. I’m working with Yocto and usually do the following steps to test a given modification:
- bitbake u-boot-tegra -C compile -f
- bitbake core-image-weston
- then extract tegraflash and execute “sudo ./doflash.sh --spi-only”
This whole process takes several minutes to complete. Is there maybe a faster way of rebuilding and updating U-Boot in the SPI flash?
Thanks for any hint!
No, there is no faster way since “dd” command no longer works on jetson nano.
When I update the devicetree only there is a slightly faster way. After Linux has been built the .dtb file can be written directly to the SPI flash with the “flash.sh -k DTB …” command. (flash.sh comes from L4T-tegra210-32.5.2-r0/Linux_for_Tegra) Isn’t there something similar for U-Boot?
Yes, there is similar case for uboot. -k LNX may flash the uboot.
Do you happen to know the exact syntax?
I tried
- sudo ./flash.sh -k LNX -L boot.img jetson-nano-2gb-devkit mmcblk0p1
and it failed with “Error: Return value 4
Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 kernel_tegra210-p3448-0003-p3542-0000.dtb 0”
I took “boot.bin” from work/jetson_nano_2gb_devkit-poky-linux/core-image-weston/1.0-r0/tegraflash
Please try
sudo ./flash.sh -r -k LNX -board name- mmcblk0p1
Witch the board name to what you are using.
