Error when burning u-boot.bin to SD card
I want to flash uboot.bin to the SD card, and I entered the following command in recovery mode:
#sudo ./flash.sh -k LNX jetson-nano-qspi-sd mmcblk0p1
It is stuck at this point and has not progressed
tegrarcm --boot recovery
Applet version 00.01.0000
Writing partition
tegradevflash --erase LNX
Cboot version 0.01.0000
Erasing partition LNX…
Hi flyhx,
Are you using the devkit from NVIDIA or custom board for Jetson Nano?
Could you flash the all partitions with the following command?
$ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
Please provide the full serial console log as file for further check.
