I’ve written the jetpack on my sd card but Jetson Nano won’t boot. this is the error I get.
It is quite likely you must flash the Nano itself once. Only the operating system is on the SD card, but the equivalent of a BIOS plus boot content must be compatible, and this is stored in the QSPI of the Nano module. You’d want the newest L4T R32.x (L4T is just Ubuntu plus NVIDIA drivers) found here:
https://developer.nvidia.com/linux-tegra
You will need a Linux host PC to perform that flash with the Jetson in recovery mode. After that different SD cards should work.
The on checking if the device is on Recovery mode, after having followed all steps in the Guide, the following error message is displayed:
jetson-nano-emmc.conf: line 31: /home/swift/Linux_for_Tegra/p3448-0000.conf.common: No such file or directory
L4T BSP Information:
R32 , REVISION: 7.1
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
The device however appears after entering the lsusb command
Please help
Is it correct that you are manually installing content for flash on the host PC? The file layout would be different if you used JetPack/SDK Manager.
If you are manually unpacking, then steps are like this (assumes you’ve downloaded and are in some directory that you can create the content in, and the directory is ext4 format):
- Unpack the “driver package” as a regular user. Do not use
sudo. - This would have created
Linux_for_Tegra/.cdinto “Linux_for_Tegra/rootfs/”. - Unpack the “sample root filesystem” with
sudo. cdback to “Linux_for_Tegra/”.- Run “
sudo ./apply_binaries.sh”.
From that point forward you can flash. From Linux_for_Tegra/ examine this:
ls -l jetson*.conf
The .conf files, if you remove the .conf suffix, are flash targets. The ones starting with “jetson-” are just aliases for the technical description. In turn, the technical description is a combination of the module model and carrier board model. Note that you have a dev kit that runs on an SD card; this model does not have eMMC.
If you wanted to flash QSPI on a nano dev kit, then looking at those .conf files, you might pick this as a flash target:
jetson-nano-qspi
(because there is a jetson-nano-qspi.conf; you could also just choose jetson-nano-devkit since that is what this is, and you can look at the model each alias points to and see that the jetson-nano-devkit target and jetson-nano-qspi are actually the same thing for this case)
Yes I am manually unpacking the driver package. This fix could not solve the issue. Could it be that the host machine is running on Ubuntu 22.04LTS, If that’s the case is there a way I can get a hold of the Ubuntu 185.04LTS version? I could not find any online.
Should I fail to get Ubuntu 18.04 LTS, is there another alternative method i can use?
Also, if the device LED does not turn green (To show it has entered Recovery Mode) does running lsusb command and having the device appear on the list enough to confirm if the device is in recovery mode?
Normally manual command line unpack and install would work on different “flavors” of Linux. There are other requirements as well sometimes, e.g., QEMU might be involved (and there is a static package as well). You will need Ubuntu 18.04 LTS (or you might see it as 18.05 if patched) to use JetPack/SDK Manager (the GUI front end and “smart” network layer). There are many alternatives if using command line, there are not really any alternatives to use the GUI (sometimes you can use Ubuntu 20.04 and lie to the software with some changes in “/etc” for the GUI, but this has no relation to command line).
Note that if a file is missing, then if the GUI wants that file, then this too would fail. What was your exact command line for the flash after a manual install? If you cd to the “Linux_for_Tegra/” directory, what do you see from this command:
`ls *.conf.common’
Also, from that same Linux_for_Tegra/ directory, what do you see from:
cat rootfs/etc/nv_tegra_release
