• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) ./deepstream-test5-app -c configs/test5_config_file_src_infer.txt
I generate NvDsEventMsgMeta in callback function named bbox_generated_probe_after_analytics . Then, I update the eventMsg->imagePath in the dsexample plug-in.When I get NvDsEventMsgMeta to generate a json format message in the nvmsgconv,I can’t get the updated image url.Why?
Part of dsexample modification
NvDsMetaList *l = NULL;
NvDsUserMeta *user_event_meta = NULL;
user_meta_list = ((NvDsFrameMeta*)frame_meta)->frame_user_meta_list;
/* Map the buffer so that it can be accessed by CPU */
if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){
if (NvBufSurfaceMap (surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED,
("%s:buffer map to be accessed by CPU failed", __func__), (NULL));
return GST_FLOW_ERROR;
/* Cache the mapped data for CPU access */
if(dsexample->inter_buf->memType == NVBUF_MEM_SURFACE_ARRAY)
NvBufSurfaceSyncForCpu (surface, frame_meta->batch_id, 0);
in_mat =
cv::Mat (surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4,
surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
for (l = user_meta_list; l; l = l->next) {
user_event_meta = (NvDsUserMeta * )(l->data);
if (user_event_meta && user_event_meta->base_meta.meta_type == NVDS_EVENT_MSG_META) {
NvDsEventMsgMeta *eventMsg = NULL;
eventMsg = (NvDsEventMsgMeta *) user_event_meta->user_meta_data;
cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2BGR);
vector<unsigned char> img_encode;
char* save_path = new char[128];
cv::imencode(".jpg", *dsexample->cvmat, img_encode);
fdfs_client->fdfs_uploadfile( img_encode.empty() ? 0 : (const char*)&img_encode[0], "jpg", img_encode.size(), save_path);
eventMsg->imagePath = save_path;
result of message, imgUrl is null
json output :{
"apISource" : "apiAction",
"equipCode" : "1000",
"videoUrl" : "file:///home/juzheng/code/deepstream-5.1/sources/apps/sample_apps/deepstream-custom-test5/configs/../../../../../samples/streams/sample_1080p_h264.mp4",
"imgUrl" : null,
"messageId" : "816bd24e-41d5-4ded-9c77-b2513e26ee3d",
"object" : {
"objRect" : [
72.231414794921875,
405.16519165039062,
242.0074462890625,
924.643798828125
"trackId" : 0,
"objClassId" : 2,
"confidence" : 0.99668914079666138,
"attrClassId" : 0,
"classifyProb" : 0.89588761329650879
"warningTime" : "2021-08-16 08:57:12",
"staffChangeTime" : "2021-08-16 08:57:12",
"memo" : ""
Part of NvDsEventMsgMeta modification
typedef struct NvDsEventMsgMeta {
//---------------------------- CUSTOM CODE --------------------------//
gchar *imagePath;
// Object meta
gint source_id;
gint frame_id;
gint object_id;
gchar *object_class;
// Bbox params
float left;
float top;
float width;
float height;
// Classifier meta
gchar *person_attr;
guint result_class_id;
gfloat classify_prob;
} NvDsEventMsgMeta;
