Leozih
September 27, 2024, 12:26pm
1
Hi guys,I am trying add my custom data to NvDsObjectMeta.It is an angle of each detected object in each frame.With this opinion,I have seen some posts in the forum,and I see the code below:
void
add_meta_to_buffer (GstBuffer * buf, gchar * meta)
NvDsBatchMeta *batch_meta;
NvDsUserMeta *user_meta;
batch_meta = gst_buffer_get_nvds_batch_meta (buf);
user_meta = nvds_acquire_user_meta_from_pool (batch_meta);
if (user_meta) {
NvDsEventMsgMeta *msg_meta =
(NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
msg_meta->otherAttrs = meta;
msg_meta->objectId = g_strdup ("custom");
user_meta->user_meta_data = (void *) msg_meta;
user_meta->base_meta.batch_meta = batch_meta;
user_meta->base_meta.meta_type = NVDS_EVENT_MSG_META;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc) custom_meta_copy_func;
user_meta->base_meta.release_func =
(NvDsMetaReleaseFunc) custom_meta_free_func;
nvds_add_user_meta_to_batch (batch_meta, user_meta);
The description is :
NvDsEventMsgMeta is a type of DeepStream user meta and there is a NvDsUserMetaList in the batch, frame and object levels of DeepStream metadata, so you can add message meta per-batch, per-frame, or per-object. We use it on the batch level adding a JSON as message meta
As you can see,it is on the batch level to add data.So what if it is on the object level?My initial opinion is :
for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = l_frame->data;
for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
user_meta = nvds_acquire_user_meta_from_pool (obj);
if (user_meta) {
NvDsEventMsgMeta *msg_meta =(NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
user_meta->base_meta.release_func =(NvDsMetaReleaseFunc) custom_meta_free_func;
nvds_add_user_meta_to_batch (obj, user_meta);
So as you can see the only difference is to replace batch_meta to obj,namely the obj_meta.The angle will be the meta parameter in the above codes.I wonder if my opinion is practical
Yes, you are right.There are some code snippets in the sample application.
Such as the following code in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvtracker/nvtracker_proc.cpp
if (m_Config.outputConvexHull && pTrackedObj->convexHull.numPointsAllocated != 0)
NvDsUserMeta *user_meta = nvds_acquire_user_meta_from_pool (pBatchMeta);
NvDsObjConvexHull* pConvexHull = new NvDsObjConvexHull;
pConvexHull->list = new int [pTrackedObj->convexHull.numPointsAllocated * 2];
for (uint32_t i=0; i < pTrackedObj->convexHull.numPoints; i++)
pConvexHull->list[2*i] = (int) (pTrackedObj->convexHull.list[2*i] * scaleWidth);
pConvexHull->list[2*i+1] = (int) (pTrackedObj->convexHull.list[2*i+1] * scaleHeight);
pConvexHull->numPoints = pTrackedObj->convexHull.numPoints;
pConvexHull->numPointsAllocated = pTrackedObj->convexHull.numPointsAllocated;
user_meta->user_meta_data = (void *)pConvexHull;
user_meta->base_meta.meta_type = (NvDsMetaType) NVDS_OBJ_IMAGE_CONVEX_HULL;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc) copy_nvtracker2_obj_convex_hull_meta;
user_meta->base_meta.release_func = (NvDsMetaReleaseFunc) free_nvtracker2_obj_convex_hull_meta;
nvds_add_user_meta_to_obj (pObjectMeta, user_meta);
Leozih
September 29, 2024, 12:50pm
4
Thanks,can I delete some lines of the codes I provide?For example:
Because I don’t define such custom function,if the two lines are deleted,any influence?
Beside, about this line:
Is it necessary to replace the batch_meta to obj?
No, this code must be exist. These callbacks will be called when meta data is copied or released between elements.
Please refer to the example above
Leozih
September 30, 2024, 2:11am
6
Thanks,could you please give me some code snippet about these callbacks?
Besides,according to your codes,this line:
seems to be unnecessary?I don’t see similar code in your codes
This depends on how you use it.
If you want to find the corresponding batchmeta when accessing objmeta, this is necessary.
Otherwise, it is not necessary.
Leozih
September 30, 2024, 8:07am
8
Thanks,could you please give me some code snippet about these callbacks?namely the :
custom_meta_copy_func and custom_meta_free_func.I don’t know how they are defined.
Leozih:
copy_func
You can refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-user-metadata-test/deepstream_user_metadata_app.c. Here is code snippet.
static gpointer copy_user_meta(gpointer data, gpointer user_data)
NvDsUserMeta *user_meta = (NvDsUserMeta *)data;
gchar *src_user_metadata = (gchar*)user_meta->user_meta_data;
gchar *dst_user_metadata = (gchar*)g_malloc0(USER_ARRAY_SIZE);
memcpy(dst_user_metadata, src_user_metadata, USER_ARRAY_SIZE);
return (gpointer)dst_user_metadata;
/* release function set by user. "data" holds a pointer to NvDsUserMeta*/
static void release_user_meta(gpointer data, gpointer user_data)
NvDsUserMeta *user_meta = (NvDsUserMeta *) data;
if(user_meta->user_meta_data) {
g_free(user_meta->user_meta_data);
user_meta->user_meta_data = NULL;
This is another sample.
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
if (!nvvidconv) {
g_printerr ("nvvidconv could not be created. Exiting.\n");
return -1;
//---Manipulate image size so that PGIE bbox is large enough---
// Enlarge image so that PeopleNet detected bbox is larger which would fully cover the
// detected object in the original sized image.
nvvideoconvert_enlarge = gst_element_factory_make("nvvideoconvert", "nvvideoconvert_enlarge");
if (!nvvideoconvert_enlarge) {
g_printerr ("nvvideoconvert_enlarge could not be created. Exiting.\n");
return -1;
capsFilter_enlarge = gst_element_factory_make("capsfilter", "capsFilter_enlarge");
if (!capsFilter_enlarge) {
g_printerr ("capsFilter_enlarge could not be created. Exiting.\n");
return -1;
Leozih
October 9, 2024, 7:48am
10
Thanks very much,I will try that later
Leozih
October 10, 2024, 12:55pm
11
Sorry to bother after so long,I notice that the
It says that “add message”.
So,if I want to add a parameter like angle to the NvDsObjectMeta, are the codes I have mentioned still works.
Leozih:
NvDsObjectMeta
It is not recommended to modify the struct NvDsObjectMeta, because some libraries are not open source and this may cause binary incompatibility.
NvDsObjectMeta has nothing to do with NvDsUserMetaList/NvDsEventMsgMeta, I don’t quite understand what you mean
Leozih
October 11, 2024, 8:11am
13
just like I have mentioned at first,I imitate some codes trying to store angle parameter by using user_meta :
if (user_meta) {
but the msg_meta which is stored seems to be “message” type, angel may be just a numble like 60 or 30.8456 and so on.I mean will this be incompatible to the msg_meta ?
No, you can think of NvDsEventMsgMeta as a handle to store “message”.
If the members of this structure do not meet your needs, you can use extMsg/extMsgSize to store custom data.
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsmeta_schema.h
/** Holds a pointer to event message meta data. This can be used to hold
data that can't be accommodated in the existing fields, or an associated
object (representing a vehicle, person, face, etc.). */
gpointer extMsg;
/** Holds the size of the custom object at @a extMsg. */
guint extMsgSize;
Refer to deepstream_test5_app_main.c
Leozih
October 11, 2024, 8:24am
15
Thanks,so you mean that in theory the angle parameter is compatible to the NvDsEventMsgMeta?
So I can just replace the meta above to angle ,then it may work.
1.If you just only want to store angle to NvDsObjectMeta. Use misc_obj_info is more simpler.
Just do the following to avoid the lengthy code of object usemeta
objmeta->misc_obj_info[0] = angle;
2.Like NvDsEventMsgMeta
typedef struct _UserObjMeta {
xxxx;
xxx;
} UserObjMeta;
// meta type defined by customer
#define NVDS_USER_OBJ_META_EXAMPLE (nvds_get_user_meta_type("NVIDIA.NVINFER.USER_META"))
if (user_meta) {
UserObjMeta *obj_meta =(UserObjMeta *) g_malloc0 (sizeof (UserObjMeta));
user_meta->user_meta_data = (void *) obj_meta;
user_meta->base_meta.meta_type = NVDS_USER_OBJ_META_EXAMPLE;
Leozih
October 11, 2024, 10:41am
17
Wow,thank you very much! misc_obj_info is really convenient and works fine!
