Creating "artificial" NvDsObjMeta and adding it to NvDsFrameMeta
I need to create a NvDsObjMeta and add it to an existing NvDsFrameMeta object.
The NvDsObjMeta is a rectangle that covers the full frame.
How should I do it? I see that we have a nvds_remove_obj_meta_from_frame method, but no nvds_add_obj_meta_to_frame.
If you want to add your own parameter, we suggest you use the user metadata. Please refer to the sample:\sources\apps\sample_apps\deepstream-user-metadata-test in the source code.
Do we have it for Python?
And also, please give me the full path if you can.
The full path:
opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-user-metadata-test
You can refer to deepstream_test_4.py to learn how to use that in python.
