I’m trying to set up IP cameras and before running the inference with deepstream, I want to test just the performance of encoding/decoding part in Deepstream. The input source would be multiple IP cameras, rtsp feed. How do I do that?
Thank you. I was able to run this. But it still runs the whole inference pipeline. I want to just use the encoding/decoding part of the pipeline? Read raw input from an IP camera and encode/decode and display as an rtsp output. I’m trying to check the performance of the pipeline in deepstream. Any suggestions to achieve this?
