I want to do follow, but I don’t have any reference. Where can I get some sdk/docments/samples?
thank you!
- Trigger camera take picture using GPIO?
- Change the trigger frequency?
thank you!
hello afhel,
there’s no samples to monitor GPIO interrupt for taking a snapshot from video streaming.
however, you may access [L4T Multimedia API Reference] and check 09_camera_jpeg_capture for an example of image captures.
in addition,
you may also refer to generic kernel APIs to trigger GPIOs,
for example,
<i>$l4t-r32.2/public_sources/kernel_src/kernel/kernel-4.9/include/linux/gpio.h</i>
static inline int gpio_get_value(unsigned int gpio)
return __gpio_get_value(gpio);
static inline void gpio_set_value(unsigned int gpio, int value)
__gpio_set_value(gpio, value);
I am struggling with this same issue. I am very new to Linux and the world is quite confusing after using only microprocessors…
When I write C-code, how do I use the gpio_get_value and _set_value? Can I just include gpio.h and the compiler will find it?
Or are there some good GPIO libraries available?
Hi dan.
You can dowload this program.
https://github.com/gaosiy/JetsonXavierGPIO
