NVIDIA / jetson-gpio
Hi, I have been trying to use the GPIO of my Jetson Xavier ARX from GitHub - NVIDIA/jetson-gpio: A Python library that enables the use of Jetson's GPIOs. I tried the sample scripts but when I tried to measure high or low values in the GPIO pins when are set as Output I don’t get any voltage. Did a miss some steps, maybe there is some guideline besides what is written in the github repo?
hello a.lopeztellez,
I assume you’re saying Jetson AGX Xavier, I’m moving this topic to a correct category.
please also access Jetson Download Center for the Jetson AGX Xavier Series Pinmux.
you should refer to the spreadsheets for the default pin configurations.
thanks
I cannot open them, What am I supposed to do with that .xml files?
are you able to access download center? i.e. [url]https://developer.nvidia.com/embedded/downloads[/url]
please try to use the filter to search for pinmux files.
thanks
Yes I found and I downloaded but I dont understand its porpose.
Thanks for your brief reply
there shows the default pin configurations,
may I know which pin you’re used and seen unexpected behaviors.
thanks
