We need 10 GPIO pins of AGX and are trying to verify J30 GPIO expansion header pins.
As we measured the signal with multimeter, we found more than 10 pins gpio did not act as we expect.
Only severl pins acted as we expected.
The pins below always kept at 0 as we set GPIO pin to output and set value to 1.
pin11 (uart1_RTS), pin13(pwm01), pin15 (GPIO27_PWM2), pin19,pin 21(SPI1_MISO)(GPIO# 492),23,35…
However pin29 CAN0_DIN, pin31, pin33 worked as the value we set.
Below is the way I tested, did I miss any?
Or those pins can not be set to GPIO?
an example : pin 21(SPI1_MISO)(GPIO# 492)
root@jetson-0423318034979:/sys/class/gpio# echo 492 > export
root@jetson-0423318034979:/sys/class/gpio# cd gpio492
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo out > direction
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo 1 > value
root@jetson-0423318034979:/sys/class/gpio/gpio492# cat value
1 ----- multimeter showed 0
root@jetson-0423318034979:/sys/class/gpio/gpio492# cat direction
out
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo 0 > value
0
