Hi, I’m using jetson nano.
I want to use mcp 3008 in jetson, but it does not work. Output is zero. I used examples from the library and library in Adafruit. The circuit connection was good according to the pin map, and the spi connection was activated.
There are a few people running this code in Raspberry Pie and Jetson nano. What is my problem? Please help me…
like this : (How to use MCP3008 in Jetson nano?)
I setup a terminal running with $ dmesg --follow, have these mesage:
lulu@lulu-desktop:~$ dmesg --follow
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5434-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:19:14 PDT 2023
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[ 0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: enabling workaround for Spectre-BHB
[ 0.000000] CPU features: enabling workaround for ARM erratum 1742098
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29724(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568248K/4159488K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 116104K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0x (ptrval) - 0x (ptrval) ( 15488 KB)
[ 0.000000] .rodata : 0x (ptrval) - 0x (ptrval) ( 6784 KB)
[ 0.000000] .init : 0x (ptrval) - 0x (ptrval) ( 8640 KB)
[ 0.000000] .data : 0x (ptrval) - 0x (ptrval) ( 2983 KB)
[ 0.000000] .bss : 0x (ptrval) - 0x (ptrval) ( 615 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001680] Console: colour dummy device 80x25
[ 0.001691] console [tty0] enabled
[ 0.001697] bootconsole [uart8250] disabled
[ 0.001716] kmemleak: Kernel memory leak detector disabled
[ 0.001735] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001748] pid_max: default: 32768 minimum: 301
[ 0.002228] Security Framework initialized
[ 0.002471] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002476] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003608] ftrace: allocating 47296 entries in 185 pages
[ 0.180137] sched-energy: CPU device node has no sched-energy-costs
[ 0.192253] ASID allocator initialised with 65536 entries
[ 0.219582] tegra-id: chipid=22117.
[ 0.219593] tegra-id: opt_subrevision=0.
[ 0.219611] Tegra Speedo/IDDQ fuse revision 4
[ 0.219616] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.219621] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.219626] Tegra: CPU Speedo Value 2056, SoC Speedo Value 1944, GPU Speedo Value 2043
[ 0.219630] Tegra: CPU IDDQ Value 1848, SoC IDDQ Value 2000, GPU IDDQ Value 2415
[ 0.219657] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.219672] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.219679] DTB Build time: Jun 8 2023 21:21:40
[ 0.269084] CPU1: Booted secondary processor [411fd071]
[ 0.300956] CPU2: Booted secondary processor [411fd071]
[ 0.332948] CPU3: Booted secondary processor [411fd071]
[ 0.333036] Brought up 4 CPUs
[ 0.333043] SMP: Total of 4 processors activated.
[ 0.333050] CPU features: detected feature: 32-bit EL0 Support
[ 0.333291] CPU: All CPU(s) started at EL2
[ 0.333308] alternatives: patching kernel code
[ 0.341436] devtmpfs: initialized
[ 0.379603] Initilizing CustomIPI irq domain
[ 0.379902] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.379923] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.391929] pinctrl core: initialized pinctrl subsystem
[ 0.392528] OS set in device tree is not L4T.
[ 0.392948] regulator-dummy: no parameters
[ 0.393255] Initializing plugin-manager
[ 0.393422] Plugin module not found
[ 0.393609] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.394111] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.395073] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.395277] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.395890] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.399463] NET: Registered protocol family 16
[ 0.400756] pstore: using zlib compression
[ 0.400798] console [pstore-1] enabled
[ 0.400802] pstore: Registered ramoops as persistent store backend
[ 0.400807] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.421100] cpuidle: using governor menu
[ 0.424262] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.426070] vdso: 2 pages (1 code @ (ptrval), 1 data @ (ptrval))
[ 0.426111] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.429495] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.431805] Serial: AMBA PL011 UART driver
[ 0.432299] tegra_powergate_init: DONE
[ 0.432316] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.432324] DTB Build time: Jun 8 2023 21:21:40
[ 0.434167] Tegra reboot handler registered.
[ 0.438662] iommu: Adding device tegra-carveouts to group 0
[ 0.438801] platform tegra-carveouts: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.439157] iommu: Adding device smmu_test to group 1
[ 0.439203] platform smmu_test: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.440026] mc: mapped MMIO address: 0x (ptrval) → 0x70019000
[ 0.440081] mc: mapped MMIO address: 0x (ptrval) → 0x7001c000
[ 0.440133] mc: mapped MMIO address: 0x (ptrval) → 0x7001d000
[ 0.440143] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.440163] mc-err: mcerr ops are set to t21x
[ 0.447415] iommu: Adding device 70090000.xusb to group 2
[ 0.447695] iommu: Adding device 70006000.serial to group 3
[ 0.447763] platform 70006000.serial: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.448174] iommu: Adding device 70006040.serial to group 4
[ 0.448439] iommu: Adding device 70006200.serial to group 5
[ 0.448662] iommu: Adding device sound to group 6
[ 0.448709] platform sound: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.449338] iommu: Adding device 7000d400.spi to group 7
[ 0.449587] iommu: Adding device 7000d600.spi to group 8
[ 0.449860] iommu: Adding device 70410000.spi to group 9
[ 0.450166] iommu: Adding device 50000000.host1x to group 10
[ 0.450442] iommu: Adding device 54080000.vi to group 11
[ 0.450820] iommu: Adding device 54600000.isp to group 12
[ 0.451105] iommu: Adding device 54680000.isp to group 13
[ 0.451370] iommu: Adding device tegradc.0 to group 14
[ 0.451422] platform tegradc.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.451941] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452257] iommu: Adding device tegradc.1 to group 15
[ 0.452306] platform tegradc.1: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.452816] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.453096] iommu: Adding device 54340000.vic to group 16
[ 0.453317] iommu: Adding device 544c0000.nvenc to group 17
[ 0.453520] iommu: Adding device 54500000.tsec to group 18
[ 0.453711] iommu: Adding device 54100000.tsecb to group 19
[ 0.453930] iommu: Adding device 54480000.nvdec to group 20
[ 0.454131] iommu: Adding device 54380000.nvjpg to group 21
[ 0.455192] iommu: Adding device 546c0000.i2c to group 22
[ 0.455530] iommu: Adding device 57000000.gpu to group 23
[ 0.455581] platform 57000000.gpu: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.455618] platform 57000000.gpu: domain= (ptrval) allocates as[1]= (ptrval)
[ 0.455655] platform 57000000.gpu: domain= (ptrval) allocates as[2]= (ptrval)
[ 0.455709] platform 57000000.gpu: domain= (ptrval) allocates as[3]= (ptrval)
[ 0.456592] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.456603] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.456615] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.456619] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.456624] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509133] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509140] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509157] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509221] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509527] iommu: Adding device 70012000.se to group 24
[ 0.510101] iommu: Adding device 1003000.pcie to group 25
[ 0.510155] platform 1003000.pcie: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.510602] iommu: Adding device 7000c000.i2c to group 26
[ 0.510854] iommu: Adding device 7000c400.i2c to group 27
[ 0.511105] iommu: Adding device 7000c500.i2c to group 28
[ 0.511362] iommu: Adding device 7000c700.i2c to group 29
[ 0.511617] iommu: Adding device 7000d000.i2c to group 30
[ 0.511864] iommu: Adding device 7000d100.i2c to group 31
[ 0.512155] iommu: Adding device sdhci-tegra.0 to group 32
[ 0.512202] platform sdhci-tegra.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.513051] iommu: Adding device 700d0000.xudc to group 33
[ 0.516304] vdd-ac-bat: 5000 mV
[ 0.516643] vdd-5v0-sys: 5000 mV
[ 0.517324] vdd-5v0-hdmi: 5000 mV
[ 0.517738] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517984] vdd-1v8-sys: 1800 mV
[ 0.518379] vdd-fan: 5000 mV
[ 0.518602] vdd-fan: supplied by vdd-5v0-sys
[ 0.518801] vdd-usb-vbus: 5000 mV
[ 0.519008] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.519342] vdd-usb-vbus2: 5000 mV
[ 0.550117] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552395] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.553606] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.553634] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.553654] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.553994] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.561744] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.562114] SCSI subsystem initialized
[ 0.562297] libata version 3.00 loaded.
[ 0.562558] usbcore: registered new interface driver usbfs
[ 0.562607] usbcore: registered new interface driver hub
[ 0.562646] usbcore: registered new device driver usb
[ 0.566559] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.572342] vdd-core: 600 ↔ 1162 mV at 1125 mV
[ 0.573392] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.576302] vdd-ddr-1v1: 1150 mV
[ 0.580233] vdd-pre-reg-1v35: 1350 mV
[ 0.584231] vdd-1v8: 1800 mV
[ 0.588230] avdd-sys-1v2: 1200 mV
[ 0.592231] vdd-pex-1v0: 1050 mV
[ 0.592894] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.593431] max77620-ldo3: at 3100 mV
[ 0.596231] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.596765] max77620-ldo5: at 3100 mV
[ 0.600237] vddio-sdmmc3-ap: 1800 ↔ 3300 mV at 2800 mV
[ 0.604229] avdd-1v05-pll: 1050 mV
[ 0.608228] avdd-io-hdmi-dp: 1050 mV
[ 0.610862] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.611196] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.611490] max77620 4-003c: max77620 probe successful
[ 0.614192] media: Linux media interface: v0.10
[ 0.614247] Linux video capture interface: v2.00
[ 0.615154] pps_core: LinuxPPS API ver. 1 registered
[ 0.615162] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.615184] PTP clock support registered
[ 0.618217] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.619078] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619676] Bluetooth: Core ver 2.22
[ 0.619723] NET: Registered protocol family 31
[ 0.619726] Bluetooth: HCI device and connection manager initialized
[ 0.619739] Bluetooth: HCI socket layer initialized
[ 0.619748] Bluetooth: L2CAP socket layer initialized
[ 0.619770] Bluetooth: SCO socket layer initialized
[ 0.621512] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621530] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.621577] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.621592] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624914] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.626036] vdd-3v3-sys: 3300 mV
[ 0.626376] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.626450] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629032] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629451] vdd-3v3-sd: 3300 mV
[ 0.629832] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.630579] avdd-io-edp-1v05: 1050 mV
[ 0.630920] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.631047] vdd-usb-hub-en: 5000 mV
[ 0.631387] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.632587] camchar: rtcpu character device driver loaded
[ 0.633350] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.634664] clocksource: Switched to clocksource arch_sys_counter
[ 0.675484] VFS: Disk quotas dquot_6.6.0
[ 0.675616] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676112] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676527] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676545] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.676729] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.676734] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.676747] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.676770] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.676775] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.676800] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.676807] nvmap_page_pool_init: Total RAM pages: 1010846
[ 0.676812] nvmap_page_pool_init: nvmap page pool size: 126355 pages (493 MB)
[ 0.676899] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677378] misc nvmap: created heap iram base 0x (ptrval) size (252KiB)
[ 0.678266] misc nvmap: created heap vpr base 0x (ptrval) size (409600KiB)
[ 0.686502] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687001] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687368] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687639] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.687816] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688104] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688108] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.688566] NET: Registered protocol family 2
[ 0.688706] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.706939] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.707149] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.707650] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.707803] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.707894] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.708316] NET: Registered protocol family 1
[ 0.709014] RPC: Registered named UNIX socket transport module.
[ 0.709020] RPC: Registered udp transport module.
[ 0.709024] RPC: Registered tcp transport module.
[ 0.709028] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.709042] PCI: CLS 0 bytes, default 64
[ 0.709283] Trying to unpack rootfs image as initramfs…
[ 1.017433] Freeing initrd memory: 6988K
[ 1.027034] host1x 50000000.host1x: initialized
[ 1.028752] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.032018] audit: initializing netlink subsys (disabled)
[ 1.032085] audit: type=2000 audit(0.875:1): initialized
[ 1.032746] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.042341] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.043873] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.044690] 9p: Installing v9fs 9p2000 file system support
[ 1.047929] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.048048] io scheduler noop registered
[ 1.048344] io scheduler cfq registered (default)
[ 1.051224] gic 702f9000.agic: GIC IRQ controller registered
[ 1.054181] iommu: Adding device 702ef000.adsp to group 34
[ 1.063372] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[ 1.063558] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.064170] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x81c8c0d
[ 1.064179] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.065737] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.065843] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.065932] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.066115] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.066205] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.066293] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.066386] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.066468] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.066555] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.066639] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.072642] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.074273] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.076173] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.077448] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.077796] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.079021] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.079236] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.079470] Adding domain tsec-pd to PM domain host1x-pd
[ 1.081550] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.082394] tsec 54500000.tsec: initialized
[ 1.083954] tsec 54100000.tsecb: initialized
[ 1.084648] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.087999] nvdec 54480000.nvdec: initialized
[ 1.089075] Adding domain vic03-pd to PM domain host1x-pd
[ 1.089262] Adding domain msenc-pd to PM domain host1x-pd
[ 1.089427] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.093323] falcon 54340000.vic: initialized
[ 1.094573] falcon 544c0000.nvenc: initialized
[ 1.095912] falcon 54380000.nvjpg: initialized
[ 1.100108] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.100153] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.100187] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.100369] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.100464] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.100469] tegra_cec 70015000.tegra_cec: probed
[ 1.100474] display board info: id 0x0, fab 0x0
[ 1.100564] generic_infoframe_type: 0x87
[ 1.100721] tegradc tegradc.0: DT parsed successfully
[ 1.100774] tegradc tegradc.0: Display dc. (ptrval) registered with id=0
[ 1.104501] tegradc tegradc.0: probed
[ 1.105189] Console: switching to colour frame buffer device 80x30
[ 1.105225] tegradc tegradc.0: fb registered
[ 1.106443] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.106530] tegradc tegradc.1: No lt-data, using default setting
[ 1.106559] tegradc tegradc.1: No hpd-gpio in DT
[ 1.106594] tegradc tegradc.1: DT parsed successfully
[ 1.106646] tegradc tegradc.1: Display dc. (ptrval) registered with id=1
[ 1.108583] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.109108] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.614890] Host read timeout at address 545c00c4
[ 1.616419] tegradc tegradc.1: probed
[ 1.616791] tegradc tegradc.1: fb registered
[ 1.617185] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.617934] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.617940] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.618208] kfuse 7000fc00.kfuse: initialized
[ 1.619104] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.619881] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.620032] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.620039] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.620048] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.620063] tegradc tegradc.1: blank - powerdown
[ 1.620084] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.620088] Extcon DP: HPD disabled
[ 1.620093] hpd: hpd_switch 0
[ 1.620099] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.620108] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.620117] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.620965] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.620977] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.621371] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.622697] vdd-gpu: applied init 1000000uV constraint
[ 1.622704] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.623075] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.626317] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.626419] No Device Node present for smmu client: serial8250 !!
[ 1.626428] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.626466] iommu: Adding device serial8250 to group 36
[ 1.628821] console [ttyS0] disabled
[ 1.628917] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.639197] console [ttyS0] enabled
[ 1.640091] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.640365] serial-tegra 70006200.serial: RX in PIO mode
[ 1.640447] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.641436] [drm] Initialized
[ 1.655881] brd: module loaded
[ 1.660997] loop: module loaded
[ 1.661085] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.661208] tegra_profiler: auth: init
[ 1.662565] THERMAL EST: found 2 subdevs
[ 1.662571] THERMAL EST num_resources: 0
[ 1.662578] [THERMAL EST subdev 0]
[ 1.662585] [THERMAL EST subdev 1]
[ 1.663094] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.663098] THERMAL EST: thz register success.
[ 1.663251] THERMAL EST: end of probe, return err: 0
[ 1.664474] sd: No Scsi addr parsed to reserve index
[ 1.664512] hisi_sas: driver version v1.6
[ 1.673706] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.675031] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.675039] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.678755] tun: Universal TUN/TAP device driver, 1.6
[ 1.678763] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.679731] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.679736] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.679789] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.679794] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.679839] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.679844] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.679892] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.679897] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.680950] PPP generic driver version 2.4.2
[ 1.681319] PPP BSD Compression module registered
[ 1.681326] PPP Deflate Compression module registered
[ 1.681368] PPP MPPE Compression module registered
[ 1.681376] NET: Registered protocol family 24
[ 1.681449] usbcore: registered new interface driver r8152
[ 1.681496] usbcore: registered new interface driver asix
[ 1.681542] usbcore: registered new interface driver ax88179_178a
[ 1.681575] usbcore: registered new interface driver cdc_ether
[ 1.681606] usbcore: registered new interface driver net1080
[ 1.681636] usbcore: registered new interface driver cdc_subset
[ 1.681670] usbcore: registered new interface driver zaurus
[ 1.681729] usbcore: registered new interface driver cdc_ncm
[ 1.681938] VFIO - User Level meta-driver version: 0.3
[ 1.683558] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.683583] ehci-pci: EHCI PCI platform driver
[ 1.683627] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.683641] ohci-pci: OHCI PCI platform driver
[ 1.683687] ohci-platform: OHCI generic platform driver
[ 1.686406] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.687046] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.688263] tegra-xusb 70090000.xusb: extcon 0: (ptrval) id
[ 1.689591] usbcore: registered new interface driver uas
[ 1.689663] usbcore: registered new interface driver usb-storage
[ 1.689858] usbcore: registered new interface driver usbserial
[ 1.692426] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[ 1.692493] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.692524] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.693318] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.693370] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.693487] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.693567] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.693574] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.693580] usb usb1: Product: xHCI Host Controller
[ 1.693585] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.693589] usb usb1: SerialNumber: 70090000.xusb
[ 1.694311] hub 1-0:1.0: USB hub found
[ 1.694449] hub 1-0:1.0: 5 ports detected
[ 1.695385] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.695403] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.695445] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.695452] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.695468] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.695596] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.695707] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.695713] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.695717] usb usb2: Product: xHCI Host Controller
[ 1.695722] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.695726] usb usb2: SerialNumber: 70090000.xusb
[ 1.695762] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.696357] hub 2-0:1.0: USB hub found
[ 1.696402] hub 2-0:1.0: 4 ports detected
[ 1.696597] mousedev: PS/2 mouse device common for all mice
[ 1.696751] usbcore: registered new interface driver xpad
[ 1.697212] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.697220] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.718748] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.781236] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.783677] rtc rtc1: alarm rtc device
[ 1.783700] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.783753] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.784416] i2c /dev entries driver
[ 1.786377] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.786804] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.786811] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.787655] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.810999] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.811089] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.818748] imx219 7-0010: board setup failed
[ 1.823220] imx219: probe of 7-0010 failed with error -121
[ 1.823856] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.847149] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.847237] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.854820] imx219 8-0010: board setup failed
[ 1.859259] imx219: probe of 8-0010 failed with error -121
[ 1.860627] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.863254] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.863261] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.863717] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.863733] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.863742] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.863879] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.863889] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.863897] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.864040] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.864050] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.864057] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.864234] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.865032] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.865088] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.865118] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.865136] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.865146] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.866031] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.866050] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.866231] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.866263] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.866733] parse_throttle_dt_data: Num cap clks = 6
[ 1.866739] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.866756] parse_throttle_dt_data: clk=gpu type=4
[ 1.866782] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.866803] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.866827] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.866832] parse_throttle_dt_data: clk=emc type=3
[ 1.867209] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.867317] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.867459] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.868235] FAN dev name: pwm-fan
[ 1.868316] FAN:gpio request success.
[ 1.868375] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.868686] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.868901] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.868911] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.869018] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.869023] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.869028] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.869033] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.869038] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.869043] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.869047] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.869052] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.869057] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.869062] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.871911] device-mapper: uevent: version 1.0.3
[ 1.872392] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.877793] tegra210-cpufreq cpufreq: probe()…completed
[ 1.878490] sdhci: Secure Digital Host Controller Interface driver
[ 1.878492] sdhci: Copyright(c) Pierre Ossman
[ 1.878494] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.879061] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.879419] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.879545] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.883860] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.884341] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.885472] usbcore: registered new interface driver usbhid
[ 1.885474] usbhid: USB HID core driver
[ 1.886897] ashmem: initialized
[ 1.887820] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.887982] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.890141] nvpmodel: initialized successfully
[ 1.891245] usbcore: registered new interface driver snd-usb-audio
[ 1.891300] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.891305] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.891323] iommu: Adding device snd-soc-dummy to group 37
[ 1.896496] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.913072] OPE platform probe
[ 1.913161] OPE platform probe successful
[ 1.913415] OPE platform probe
[ 1.913495] OPE platform probe successful
[ 1.926912] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.937610] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 1.937745] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 1.937875] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 1.938008] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 1.938134] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 1.938263] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 1.938394] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 1.938523] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 1.938685] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 1.938823] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 1.942732] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.950294] u32 classifier
[ 1.950297] Actions configured
[ 1.950370] Initializing XFRM netlink socket
[ 1.951144] NET: Registered protocol family 10
[ 1.951821] NET: Registered protocol family 17
[ 1.951831] NET: Registered protocol family 15
[ 1.951914] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.951957] Bluetooth: RFCOMM socket layer initialized
[ 1.951973] Bluetooth: RFCOMM ver 1.11
[ 1.951978] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.951983] Bluetooth: HIDP socket layer initialized
[ 1.952001] 9pnet: Installing 9P2000 support
[ 1.952049] Key type dns_resolver registered
[ 1.952455] Registered cp15_barrier emulation handler
[ 1.952462] Registered setend emulation handler
[ 1.953506] registered taskstats version 1
[ 1.954033] Adding domain ve2-pd to PM domain host1x-pd
[ 1.954281] Adding domain ve-pd to PM domain host1x-pd
[ 1.957196] isp 54600000.isp: initialized
[ 1.958571] isp 54680000.isp: initialized
[ 1.968962] last reset is due to power on reset
[ 1.968966] KERNEL: PMC reset status reg: 0x0
[ 1.969028] BL: PMC reset status reg: 0x0
[ 1.969031] BL: PMIC poweroff Event Recorder: 0x40
[ 1.970453] clk_cbus_recalc_rate: no gbus parent
[ 1.970459] clk_cbus_round_rate: no gbus parent
[ 1.970461] clk_cbus_round_rate: no gbus parent
[ 1.970466] clk_cbus_recalc_rate: no gbus parent
[ 1.970563] clk_cbus_recalc_rate: no gbus parent
[ 1.970567] clk_cbus_round_rate: no gbus parent
[ 1.970569] clk_cbus_round_rate: no gbus parent
[ 1.970573] clk_cbus_recalc_rate: no gbus parent
[ 1.971238] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.971243] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.971247] usb 1-2: Product: USB2.1 Hub
[ 1.971250] usb 1-2: Manufacturer: Generic
[ 1.971268] tegra_dvfs: GPU-cap: registered
[ 1.971325] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.971327] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.971330] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.972221] hub 1-2:1.0: USB hub found
[ 1.972762] tegra_dvfs: vdd-gpu-vts: registered
[ 1.972800] hub 1-2:1.0: 5 ports detected
[ 1.973465] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.974062] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.974582] input: gpio-keys as /devices/gpio-keys/input/input1
[ 2.008160] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 2.009165] vi 54080000.vi: vi_probe: ++
[ 2.012179] vi 54080000.vi: initialized
[ 2.014261] vi 54080000.vi: subdev nvcsi–2 bound
[ 2.014364] vi 54080000.vi: subdev nvcsi–1 bound
[ 2.015195] Disable partitions left on by BL
[ 2.015198] disb
[ 2.015239] bwmgr: missing cdev-type property
[ 2.015362] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.015369] DRAM derating cdev registered.
[ 2.016294] ALSA device list:
[ 2.016297] #0: tegra-hda at 0x70038000 irq 83
[ 2.016300] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.019622] Freeing unused kernel memory: 8640K
[ 2.026687] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.043871] Root device found: mmcblk0p1
[ 2.098673] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.106721] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.106724] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.118668] usb 1-2: usb_suspend_both: status 0
[ 2.119086] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.125224] mmc0: hw tuning done …
[ 2.125260] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.125620] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 2.130983] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.146667] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 2.146672] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.146676] usb 2-1: Product: USB3.2 Hub
[ 2.146680] usb 2-1: Manufacturer: Generic
[ 2.147630] hub 2-1:1.0: USB hub found
[ 2.148383] hub 2-1:1.0: 4 ports detected
[ 2.206862] usb usb1: usb_suspend_both: status 0
[ 2.248876] Found dev node: /dev/mmcblk0p1
[ 2.282588] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
[ 2.298721] usb 2-1: usb_suspend_both: status 0
[ 2.298848] usb usb2: usb_suspend_both: status 0
[ 2.311914] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.313835] Rootfs mounted over mmcblk0p1
[ 2.345058] Switching from initrd to actual rootfs
[ 2.430668] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.548991] systemd[1]: System time before build time, advancing clock.
[ 2.592101] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.604844] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.627712] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.628493] systemd[1]: Detected architecture arm64.
[ 2.651268] systemd[1]: Set hostname to .
[ 2.779375] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.779384] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.842674] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.844694] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.943827] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.943866] systemd[1]: Reached target User and Group Name Lookups.
[ 2.944183] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.945988] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.946024] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.946050] systemd[1]: Reached target Mounting snaps.
[ 2.946091] systemd[1]: Reached target Mounted snaps.
[ 2.948054] systemd[1]: Created slice System Slice.
[ 2.950023] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.950029] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.950033] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.950040] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.950045] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.950067] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.950138] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.950268] iommu: Adding device 0000:00:02.0 to group 38
[ 2.950343] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.950454] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.950480] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.950514] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.950535] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.950729] pci 0000:01:00.0: supports D1 D2
[ 2.950732] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.950905] iommu: Adding device 0000:01:00.0 to group 39
[ 2.962780] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.962812] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.962817] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.962824] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.962843] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.962861] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.962870] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.962874] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.962879] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.963177] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.963181] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.963186] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.963285] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.963475] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.963494] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.977950] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.978022] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:f5:ba:fd from device tree
[ 2.978506] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.978520] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.008428] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.147608] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.328311] systemd-journald[1944]: Received request to flush runtime journal from PID 1
[ 3.946868] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 3.994688] tegra-xusb 70090000.xusb: entering ELPG
[ 3.995725] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 3.995925] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 3.997835] tegra-xusb 70090000.xusb: entering ELPG done
[ 4.047057] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.049077] random: systemd-journal: uninitialized urandom read (16 bytes read)
[ 4.282111] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.282133] cpu-throttle-alert cooling device registered.
[ 4.282274] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.282288] gpu-throttle-alert cooling device registered.
[ 4.282472] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.282485] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.282499] hot-surface-alert cooling device registered.
[ 4.550686] random: crng init done
[ 4.554093] random: 228 urandom warning(s) missed due to ratelimiting
[ 4.698134] using random self ethernet address
[ 4.702726] using random host ethernet address
[ 5.764739] Mass Storage Function, version: 2009/09/11
[ 5.764744] LUN: removable file: (no medium)
[ 5.770002] using random self ethernet address
[ 5.774543] using random host ethernet address
[ 5.851613] rndis0: HOST MAC a6:95:54:9c:44:7c
[ 5.851859] rndis0: MAC a6:95:54:9c:44:7d
[ 5.852660] usb0: HOST MAC a6:95:54:9c:44:7e
[ 5.852855] usb0: MAC a6:95:54:9c:44:7f
[ 5.852877] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.853622] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.853642] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.853674] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.854000] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.854023] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.854729] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.854742] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.855091] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.861948] l4tbr0: port 1(rndis0) entered blocking state
[ 5.861952] l4tbr0: port 1(rndis0) entered disabled state
[ 5.862119] device rndis0 entered promiscuous mode
[ 5.871832] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.878240] l4tbr0: port 2(usb0) entered blocking state
[ 5.878245] l4tbr0: port 2(usb0) entered disabled state
[ 5.879111] device usb0 entered promiscuous mode
[ 5.887944] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.967965] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.991352] eth0: 0xffffff800ab93000, 48:b0:2d:f5:ba:fd, IRQ 407
[ 6.041257] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.304052] zram: Added device: zram0
[ 6.306888] zram: Added device: zram1
[ 6.310852] zram: Added device: zram2
[ 6.314639] zram: Added device: zram3
[ 6.359851] zram0: detected capacity change from 0 to 519553024
[ 6.685155] Adding 507372k swap on /dev/zram0. Priority:5 extents:1 across:507372k SS
[ 6.691411] zram1: detected capacity change from 0 to 519553024
[ 6.702907] Adding 507372k swap on /dev/zram1. Priority:5 extents:1 across:507372k SS
[ 6.706245] zram2: detected capacity change from 0 to 519553024
[ 6.717244] Adding 507372k swap on /dev/zram2. Priority:5 extents:1 across:507372k SS
[ 6.720740] zram3: detected capacity change from 0 to 519553024
[ 6.731836] Adding 507372k swap on /dev/zram3. Priority:5 extents:1 across:507372k SS
[ 7.988230] Bridge firewalling registered
[ 8.008596] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.090695] r8168: eth0: link up
[ 8.090732] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.147186] Netfilter messages via NETLINK v0.30.
[ 8.150114] ctnetlink v0.93: registering with nfnetlink.
[ 8.259354] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 8.822602] tegradc tegradc.0: blank - powerdown
[ 8.822612] tegradc tegradc.1: blank - powerdown
[ 9.695191] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 9.702144] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 9.891198] tegra-xusb 70090000.xusb: exiting ELPG
[ 9.891525] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 9.894689] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[ 9.894964] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 9.894984] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 9.895002] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 10.026755] tegra-xusb 70090000.xusb: exiting ELPG done
[ 10.054910] usb usb2: usb_suspend_both: status 0
[ 10.239709] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 10.246564] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 10.402691] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 10.422790] usb 1-2: usb_suspend_both: status 0
[ 10.422881] usb usb1: usb_suspend_both: status 0
[ 10.628468] fuse init (API version 7.26)
[ 12.030736] tegra-xusb 70090000.xusb: entering ELPG
[ 12.031770] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 12.031962] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 12.033527] tegra-xusb 70090000.xusb: entering ELPG done
[ 12.981859] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.981868] Bluetooth: BNEP socket layer initialized
[ 33.917359] vdd-fan: disabling
[ 33.917404] vdd-usb-vbus: disabling
[ 33.917437] vdd-usb-vbus2: disabling
[ 33.917544] vddio-sdmmc3-ap: disabling
[ 33.918243] avdd-io-edp-1v05: disabling
[ 33.918276] vdd-usb-hub-en: disabling
[ 316.536733] EXT4-fs (mmcblk0p1): error count since last fsck: 1
[ 316.542961] EXT4-fs (mmcblk0p1): initial error at time 1713843068: ext4_find_entry:1478: inode 549403
[ 316.552418] EXT4-fs (mmcblk0p1): last error at time 1713843068: ext4_find_entry:1478: inode 549403
[ 1161.339169] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 1161.345936] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 1350.107176] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 1350.113922] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
