jetson@tegra-ubuntu:~$ sudo ./spidev_test -D /dev/spidev0.0 -v -p "HelloWorld123456789abcdef" -g 16
/dev/spidev0.0: TEST FAILED !!!!! (status:-1)
jetson@tegra-ubuntu:~$ sudo ./spidev_test -D /dev/spidev0.1 -v -p "HelloWorld123456789abcdef" -g 16
/dev/spidev0.1: TEST FAILED !!!!! (status:-1)
jetson@tegra-ubuntu:~$ sudo ./spidev_test -D /dev/spidev1.0 -v -p "HelloWorld123456789abcdef" -g 16
/dev/spidev1.0: TEST FAILED !!!!! (status:-1)
jetson@tegra-ubuntu:~$ sudo ./spidev_test -D /dev/spidev1.1 -v -p "HelloWorld123456789abcdef" -g 16
/dev/spidev1.1: TEST FAILED !!!!! (status:-1)
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (root@haipubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #74 SMP PREEMPT Wed Aug 30 11:27:52 CEST 2023
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty1 fbcon=map:1 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29300(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568656K/4159488K available (15294K kernel code, 2944K rwdata, 6768K rodata, 8576K init, 611K bss, 115696K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a150008 ( 2945 KB)
[ 0.000000] .bss : 0xffffff800a150008 - 0xffffff800a1e8cbc ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001423] Console: colour dummy device 80x25
[ 0.001440] console [tty0] enabled
[ 0.001457] kmemleak: Kernel memory leak detector disabled
[ 0.001475] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001489] pid_max: default: 32768 minimum: 301
[ 0.001939] Security Framework initialized
[ 0.002158] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002166] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003280] ftrace: allocating 47198 entries in 185 pages
[ 0.172271] sched-energy: CPU device node has no sched-energy-costs
[ 0.172304] ASID allocator initialised with 65536 entries
[ 0.211279] tegra-id: chipid=22117.
[ 0.211291] tegra-id: opt_subrevision=0.
[ 0.211309] Tegra Speedo/IDDQ fuse revision 4
[ 0.211314] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211318] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211323] Tegra: CPU Speedo Value 2031, SoC Speedo Value 1965, GPU Speedo Value 2056
[ 0.211327] Tegra: CPU IDDQ Value 1604, SoC IDDQ Value 1944, GPU IDDQ Value 2305
[ 0.211346] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211363] DTS File Name: /home/haip-ubuntu/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.211370] DTB Build time: Sep 22 2023 14:13:07
[ 0.261053] CPU1: Booted secondary processor [411fd071]
[ 0.292956] CPU2: Booted secondary processor [411fd071]
[ 0.324934] CPU3: Booted secondary processor [411fd071]
[ 0.325030] Brought up 4 CPUs
[ 0.325037] SMP: Total of 4 processors activated.
[ 0.325045] CPU features: detected feature: 32-bit EL0 Support
[ 0.325305] CPU: All CPU(s) started at EL2
[ 0.325322] alternatives: patching kernel code
[ 0.333485] devtmpfs: initialized
[ 0.368094] Initilizing CustomIPI irq domain
[ 0.368461] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368485] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.379011] pinctrl core: initialized pinctrl subsystem
[ 0.379586] OS set in device tree is not L4T.
[ 0.380004] regulator-dummy: no parameters
[ 0.380269] Initializing plugin-manager
[ 0.380419] Plugin module not found
[ 0.380612] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.381168] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.381584] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.382294] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.382498] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.382929] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.383583] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[ 0.386286] NET: Registered protocol family 16
[ 0.389814] pstore: using zlib compression
[ 0.389855] console [pstore-1] enabled
[ 0.389860] pstore: Registered ramoops as persistent store backend
[ 0.389865] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405072] cpuidle: using governor menu
[ 0.408635] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410195] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.410218] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413457] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415475] Serial: AMBA PL011 UART driver
[ 0.415976] tegra_powergate_init: DONE
[ 0.415991] DTS File Name: /home/haip-ubuntu/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.415996] DTB Build time: Sep 22 2023 14:13:07
[ 0.417570] Tegra reboot handler registered.
[ 0.421949] iommu: Adding device tegra-carveouts to group 0
[ 0.422080] platform tegra-carveouts: domain=ffffffc0f9ba93d8 allocates as[0]=ffffffc0f9bcc0a8
[ 0.422421] iommu: Adding device smmu_test to group 1
[ 0.422468] platform smmu_test: domain=ffffffc0f9ba9618 allocates as[0]=ffffffc0f9bcc110
[ 0.423277] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.423331] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.423387] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.423396] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.423416] mc-err: mcerr ops are set to t21x
[ 0.433987] iommu: Adding device 70090000.xusb to group 2
[ 0.434268] iommu: Adding device 70006000.serial to group 3
[ 0.434339] platform 70006000.serial: domain=ffffffc0f9498618 allocates as[0]=ffffffc0f9bcc178
[ 0.434745] iommu: Adding device 70006040.serial to group 4
[ 0.435004] iommu: Adding device 70006200.serial to group 5
[ 0.435229] iommu: Adding device sound to group 6
[ 0.435275] platform sound: domain=ffffffc0f9498b58 allocates as[0]=ffffffc0f9bcc1e0
[ 0.435825] iommu: Adding device 7000d400.spi to group 7
[ 0.436085] iommu: Adding device 7000d600.spi to group 8
[ 0.436414] iommu: Adding device 50000000.host1x to group 9
[ 0.436694] iommu: Adding device 54080000.vi to group 10
[ 0.437288] iommu: Adding device 54600000.isp to group 11
[ 0.437564] iommu: Adding device 54680000.isp to group 12
[ 0.437835] iommu: Adding device tegradc.0 to group 13
[ 0.437912] platform tegradc.0: domain=ffffffc0f94a5918 allocates as[0]=ffffffc0f9bcc248
[ 0.438428] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.438746] iommu: Adding device tegradc.1 to group 14
[ 0.438793] platform tegradc.1: domain=ffffffc0f94a5b58 allocates as[0]=ffffffc0f9bcc2b0
[ 0.439302] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.439548] iommu: Adding device 54340000.vic to group 15
[ 0.439751] iommu: Adding device 544c0000.nvenc to group 16
[ 0.439945] iommu: Adding device 54500000.tsec to group 17
[ 0.440143] iommu: Adding device 54100000.tsecb to group 18
[ 0.440352] iommu: Adding device 54480000.nvdec to group 19
[ 0.440541] iommu: Adding device 54380000.nvjpg to group 20
[ 0.441676] iommu: Adding device 546c0000.i2c to group 21
[ 0.442019] iommu: Adding device 57000000.gpu to group 22
[ 0.442071] platform 57000000.gpu: domain=ffffffc0f94afb58 allocates as[0]=ffffffc0f9bcc318
[ 0.442106] platform 57000000.gpu: domain=ffffffc0f94afb58 allocates as[1]=ffffffc0f9bcc380
[ 0.442143] platform 57000000.gpu: domain=ffffffc0f94afb58 allocates as[2]=ffffffc0f9bcc3e8
[ 0.442179] platform 57000000.gpu: domain=ffffffc0f94afb58 allocates as[3]=ffffffc0f9bcc450
[ 0.443037] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.443049] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.443060] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.443063] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.443067] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.493119] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.493128] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493146] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493207] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493504] iommu: Adding device 70012000.se to group 23
[ 0.494275] iommu: Adding device 7000c000.i2c to group 24
[ 0.494540] iommu: Adding device 7000c400.i2c to group 25
[ 0.494785] iommu: Adding device 7000c500.i2c to group 26
[ 0.495035] iommu: Adding device 7000c700.i2c to group 27
[ 0.495284] iommu: Adding device 7000d000.i2c to group 28
[ 0.495562] iommu: Adding device 7000d100.i2c to group 29
[ 0.495827] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.495885] platform sdhci-tegra.3: domain=ffffffc0f9566cd8 allocates as[0]=ffffffc0f9bcc4b8
[ 0.496322] iommu: Adding device sdhci-tegra.2 to group 31
[ 0.496377] platform sdhci-tegra.2: domain=ffffffc0f9566f18 allocates as[0]=ffffffc0f9bcc520
[ 0.497255] iommu: Adding device 700d0000.xudc to group 32
[ 0.500407] vdd-ac-bat: 5000 mV
[ 0.500754] vdd-5v0-sys: 5000 mV
[ 0.501759] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.501804] vdd-5v0-hdmi: 5000 mV
[ 0.502198] vdd-1v8-sys: 1800 mV
[ 0.502583] vdd-fan: supplied by vdd-5v0-sys
[ 0.502621] vdd-fan: 5000 mV
[ 0.503038] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.503075] vdd-usb-vbus: 5000 mV
[ 0.503600] vdd-usb-vbus2: 5000 mV
[ 0.538060] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540482] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.541639] GPIO line 152 (camera-control-output-low) hogged as output/high
[ 0.541660] GPIO line 151 (camera-control-output-low) hogged as output/high
[ 0.541692] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.542067] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.550094] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.550436] SCSI subsystem initialized
[ 0.550644] libata version 3.00 loaded.
[ 0.550963] usbcore: registered new interface driver usbfs
[ 0.551015] usbcore: registered new interface driver hub
[ 0.551095] usbcore: registered new device driver usb
[ 0.555247] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.560338] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.561264] random: fast init done
[ 0.561280] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564228] vdd-ddr-1v1: 1150 mV
[ 0.568340] vdd-pre-reg-1v35: 1350 mV
[ 0.572230] vdd-1v8: 1800 mV
[ 0.576225] avdd-sys-1v2: 1200 mV
[ 0.580226] vdd-pex-1v0: 1050 mV
[ 0.580891] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.581459] max77620-ldo3: at 3100 mV
[ 0.584232] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.584773] max77620-ldo5: at 3100 mV
[ 0.588227] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.592234] avdd-1v05-pll: 1050 mV
[ 0.596227] avdd-io-hdmi-dp: 1050 mV
[ 0.598696] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.599018] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.599319] max77620 4-003c: max77620 probe successful
[ 0.602091] media: Linux media interface: v0.10
[ 0.602149] Linux video capture interface: v2.00
[ 0.603058] pps_core: LinuxPPS API ver. 1 registered
[ 0.603063] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.603096] PTP clock support registered
[ 0.606234] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.607047] Advanced Linux Sound Architecture Driver Initialized.
[ 0.607707] Bluetooth: Core ver 2.22
[ 0.607752] NET: Registered protocol family 31
[ 0.607757] Bluetooth: HCI device and connection manager initialized
[ 0.607771] Bluetooth: HCI socket layer initialized
[ 0.607780] Bluetooth: L2CAP socket layer initialized
[ 0.607806] Bluetooth: SCO socket layer initialized
[ 0.609581] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.609597] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.609644] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.609659] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.612542] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.613860] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.613946] vdd-3v3-sys: 3300 mV
[ 0.614220] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.616295] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.616746] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.616781] vdd-3v3-sd: 3300 mV
[ 0.617697] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.617740] avdd-io-edp-1v05: 1050 mV
[ 0.618175] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.618215] vdd-usb-hub-en: 5000 mV
[ 0.619577] camchar: rtcpu character device driver loaded
[ 0.620338] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.621682] clocksource: Switched to clocksource arch_sys_counter
[ 0.661629] VFS: Disk quotas dquot_6.6.0
[ 0.661820] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.662302] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.662711] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.662730] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.662920] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.662925] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.662937] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.662965] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.662971] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.662982] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.662988] nvmap_page_pool_init: Total RAM pages: 1010948
[ 0.662993] nvmap_page_pool_init: nvmap page pool size: 126368 pages (493 MB)
[ 0.663082] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.663582] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.664491] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.672899] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.673329] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.673710] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.673991] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.674170] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.674449] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.674453] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.674882] NET: Registered protocol family 2
[ 0.675869] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.676082] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.676577] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.676727] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.676807] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.677224] NET: Registered protocol family 1
[ 0.678007] RPC: Registered named UNIX socket transport module.
[ 0.678012] RPC: Registered udp transport module.
[ 0.678016] RPC: Registered tcp transport module.
[ 0.678020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.678034] PCI: CLS 0 bytes, default 64
[ 0.678262] Trying to unpack rootfs image as initramfs...
[ 0.981025] Freeing initrd memory: 6992K
[ 0.990496] host1x 50000000.host1x: initialized
[ 0.992318] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.995573] audit: initializing netlink subsys (disabled)
[ 0.995639] audit: type=2000 audit(0.847:1): initialized
[ 0.996390] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.006350] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.007797] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.008582] 9p: Installing v9fs 9p2000 file system support
[ 1.011865] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.012010] io scheduler noop registered
[ 1.012301] io scheduler cfq registered (default)
[ 1.015139] gic 702f9000.agic: GIC IRQ controller registered
[ 1.018128] iommu: Adding device 702ef000.adsp to group 33
[ 1.026903] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.027043] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.027595] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8228c11
[ 1.027603] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.029140] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.029236] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.029331] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.029524] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.029606] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.029734] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.029830] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.029925] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.030015] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.030101] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.036602] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.038241] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.040074] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.041328] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.041774] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.042954] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.043175] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=3000000, max_bw=3000000
[ 1.043458] Adding domain tsec-pd to PM domain host1x-pd
[ 1.045256] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.046139] tsec 54500000.tsec: initialized
[ 1.047671] tsec 54100000.tsecb: initialized
[ 1.048332] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.051343] nvdec 54480000.nvdec: initialized
[ 1.052366] Adding domain vic03-pd to PM domain host1x-pd
[ 1.052543] Adding domain msenc-pd to PM domain host1x-pd
[ 1.052701] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.056339] falcon 54340000.vic: initialized
[ 1.057547] falcon 544c0000.nvenc: initialized
[ 1.058985] falcon 54380000.nvjpg: initialized
[ 1.063236] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.063281] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.063315] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.063344] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.063435] display board info: id 0x0, fab 0x0
[ 1.063487] generic_infoframe_type: 0x87
[ 1.063604] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.063612] tegra_cec 70015000.tegra_cec: probed
[ 1.063638] tegradc tegradc.0: DT parsed successfully
[ 1.063687] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.071282] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.071737] tegradc tegradc.0: probed
[ 1.072112] tegradc tegradc.0: fb registered
[ 1.073374] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.073456] tegradc tegradc.1: No lt-data, using default setting
[ 1.073480] tegradc tegradc.1: No hpd-gpio in DT
[ 1.073512] tegradc tegradc.1: DT parsed successfully
[ 1.073560] tegradc tegradc.1: Display dc.ffffff800ad00000 registered with id=1
[ 1.075079] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.077205] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.077889] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.077893] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.078175] kfuse 7000fc00.kfuse: initialized
[ 1.078906] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.079679] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.080511] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.080520] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.080886] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.082713] vdd-gpu: applied init 1000000uV constraint
[ 1.082723] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.083122] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.587353] Host read timeout at address 545c00c4
[ 1.593334] tegradc tegradc.1: probed
[ 1.593947] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.594066] Console: switching to colour frame buffer device 80x30
[ 1.594070] No Device Node present for smmu client: serial8250 !!
[ 1.594076] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.594102] tegradc tegradc.1: fb registered
[ 1.594119] iommu: Adding device serial8250 to group 35
[ 1.596649] console [ttyS0] disabled
[ 1.596712] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.597622] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.597627] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.597636] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.606994] console [ttyS0] enabled
[ 1.607009] tegradc tegradc.1: blank - powerdown
[ 1.607086] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.607092] Extcon DP: HPD disabled
[ 1.607096] hpd: hpd_switch 0
[ 1.607101] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.607114] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.607121] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.608006] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.608340] serial-tegra 70006200.serial: RX in PIO mode
[ 1.608442] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.609437] [drm] Initialized
[ 1.659741] brd: module loaded
[ 1.697010] loop: module loaded
[ 1.697107] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.697219] tegra_profiler: auth: init
[ 1.698620] THERMAL EST: found 2 subdevs
[ 1.698630] THERMAL EST num_resources: 0
[ 1.698636] [THERMAL EST subdev 0]
[ 1.698645] [THERMAL EST subdev 1]
[ 1.699107] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.699110] THERMAL EST: thz register success.
[ 1.699287] THERMAL EST: end of probe, return err: 0
[ 1.700427] sd: No Scsi addr parsed to reserve index
[ 1.700462] hisi_sas: driver version v1.6
[ 1.706727] libphy: Fixed MDIO Bus: probed
[ 1.707428] tun: Universal TUN/TAP device driver, 1.6
[ 1.707433] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.708583] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.708588] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.708630] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.708634] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.708673] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.708677] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.708722] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.708726] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.714115] PPP generic driver version 2.4.2
[ 1.714334] PPP BSD Compression module registered
[ 1.714340] PPP Deflate Compression module registered
[ 1.714381] PPP MPPE Compression module registered
[ 1.714387] NET: Registered protocol family 24
[ 1.714471] usbcore: registered new interface driver r8152
[ 1.714517] usbcore: registered new interface driver asix
[ 1.714566] usbcore: registered new interface driver ax88179_178a
[ 1.714607] usbcore: registered new interface driver cdc_ether
[ 1.714649] usbcore: registered new interface driver net1080
[ 1.714688] usbcore: registered new interface driver cdc_subset
[ 1.714728] usbcore: registered new interface driver zaurus
[ 1.714781] usbcore: registered new interface driver cdc_ncm
[ 1.714965] VFIO - User Level meta-driver version: 0.3
[ 1.720232] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.720257] ehci-pci: EHCI PCI platform driver
[ 1.720300] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.720313] ohci-pci: OHCI PCI platform driver
[ 1.720363] ohci-platform: OHCI generic platform driver
[ 1.723019] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.723635] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.724820] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90ba000 id
[ 1.726043] usbcore: registered new interface driver uas
[ 1.726109] usbcore: registered new interface driver usb-storage
[ 1.726230] usbcore: registered new interface driver usbserial
[ 1.730220] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.731829] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.731886] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.731893] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.731901] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.731927] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.732475] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.732704] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.732761] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.732783] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.733022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.733030] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.733035] usb usb1: Product: xHCI Host Controller
[ 1.733040] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.733045] usb usb1: SerialNumber: 70090000.xusb
[ 1.733093] mousedev: PS/2 mouse device common for all mice
[ 1.733214] usbcore: registered new interface driver xpad
[ 1.733735] hub 1-0:1.0: USB hub found
[ 1.733848] hub 1-0:1.0: 5 ports detected
[ 1.734454] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.734472] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.734581] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.734698] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.734705] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.734710] usb usb2: Product: xHCI Host Controller
[ 1.734715] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.734719] usb usb2: SerialNumber: 70090000.xusb
[ 1.735249] hub 2-0:1.0: USB hub found
[ 1.735284] hub 2-0:1.0: 4 ports detected
[ 1.736025] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.736032] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.837834] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.838093] usb usb2: usb_suspend_both: status 0
[ 1.862914] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.865450] rtc rtc1: alarm rtc device
[ 1.865469] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.865503] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.866244] i2c /dev entries driver
[ 1.868866] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.871867] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.871875] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.872329] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.872348] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.872359] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.872524] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.872538] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.872545] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.872692] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.872703] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.872710] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.872889] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.873777] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.873839] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.873866] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.873884] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.873892] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.874981] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.875003] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.875238] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.875267] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.875758] parse_throttle_dt_data: Num cap clks = 6
[ 1.875765] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.875780] parse_throttle_dt_data: clk=gpu type=4
[ 1.875808] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.875831] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.875855] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.875859] parse_throttle_dt_data: clk=emc type=3
[ 1.876342] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.876494] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.876689] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.877526] FAN dev name: pwm-fan
[ 1.877612] FAN:gpio request success.
[ 1.877626] FAN: can't find tach_gpio
[ 1.877704] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.878028] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.878036] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.878160] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.878166] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.878172] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.878177] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.878182] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.878187] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.878192] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.878197] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.878202] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.878207] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.881183] device-mapper: uevent: version 1.0.3
[ 1.881736] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.887220] tegra210-cpufreq cpufreq: probe()...completed
[ 1.888073] sdhci: Secure Digital Host Controller Interface driver
[ 1.888075] sdhci: Copyright(c) Pierre Ossman
[ 1.888077] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.888425] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.892025] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 1.896565] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.897072] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.898265] usbcore: registered new interface driver usbhid
[ 1.898268] usbhid: USB HID core driver
[ 1.900500] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.900669] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.902465] nvpmodel: initialized successfully
[ 1.903533] usbcore: registered new interface driver snd-usb-audio
[ 1.903589] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.903594] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.903611] iommu: Adding device snd-soc-dummy to group 36
[ 1.909773] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.926563] OPE platform probe
[ 1.926651] OPE platform probe successful
[ 1.926907] OPE platform probe
[ 1.926997] OPE platform probe successful
[ 1.929716] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.941765] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 1.952793] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.952930] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.953062] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.953188] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.953318] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.953450] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.953577] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.953726] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.953854] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.953982] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.966063] u32 classifier
[ 1.966066] Actions configured
[ 1.966139] Initializing XFRM netlink socket
[ 1.966836] NET: Registered protocol family 10
[ 1.967520] NET: Registered protocol family 17
[ 1.967532] NET: Registered protocol family 15
[ 1.967605] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.967650] Bluetooth: RFCOMM socket layer initialized
[ 1.967660] Bluetooth: RFCOMM ver 1.11
[ 1.967665] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.967670] Bluetooth: HIDP socket layer initialized
[ 1.967689] 9pnet: Installing 9P2000 support
[ 1.967722] Key type dns_resolver registered
[ 1.968116] Registered cp15_barrier emulation handler
[ 1.968123] Registered setend emulation handler
[ 1.969204] bootconsole [uart8250] disabled
[ 1.969235] registered taskstats version 1
[ 1.969783] Adding domain ve2-pd to PM domain host1x-pd
[ 1.970034] Adding domain ve-pd to PM domain host1x-pd
[ 1.971989] isp 54600000.isp: initialized
[ 1.973934] isp 54680000.isp: initialized
[ 1.984080] last reset is due to software reset
[ 1.984084] KERNEL: PMC reset status reg: 0x3
[ 1.984143] BL: PMC reset status reg: 0x3
[ 1.984145] BL: PMIC poweroff Event Recorder: 0x0
[ 1.984906] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.985575] clk_cbus_recalc_rate: no gbus parent
[ 1.985579] clk_cbus_round_rate: no gbus parent
[ 1.985582] clk_cbus_round_rate: no gbus parent
[ 1.985587] clk_cbus_recalc_rate: no gbus parent
[ 1.985696] clk_cbus_recalc_rate: no gbus parent
[ 1.985699] clk_cbus_round_rate: no gbus parent
[ 1.985701] clk_cbus_round_rate: no gbus parent
[ 1.985705] clk_cbus_recalc_rate: no gbus parent
[ 1.985750] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.986401] tegra_dvfs: GPU-cap: registered
[ 1.986457] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.986459] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.986462] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.987832] tegra_dvfs: vdd-gpu-vts: registered
[ 1.988514] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.989084] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.989259] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.989440] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 1.989559] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 1.989607] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.989858] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 1.992323] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.022708] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:28 UTC (946688428)
[ 2.023673] vi 54080000.vi: vi_probe: ++
[ 2.026299] vi 54080000.vi: initialized
[ 2.028297] vi 54080000.vi: subdev nvcsi--2 bound
[ 2.028387] vi 54080000.vi: subdev nvcsi--1 bound
[ 2.028636] mmcblk mmc0:0001: Card claimed for testing.
[ 2.029798] Disable partitions left on by BL
[ 2.029801] disb
[ 2.029843] bwmgr: missing cdev-type property
[ 2.029969] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.029976] DRAM derating cdev registered.
[ 2.030813] ALSA device list:
[ 2.030816] #0: tegra-hda at 0x70038000 irq 82
[ 2.030818] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.034005] Freeing unused kernel memory: 8576K
[ 2.057704] Root device found: mmcblk0p1
[ 2.059136] Found dev node: /dev/mmcblk0p1
[ 2.061761] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.065712] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.065729] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.091323] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.091327] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.091330] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.091333] usb 1-2: Manufacturer: Generic
[ 2.092234] hub 1-2:1.0: USB hub found
[ 2.092803] hub 1-2:1.0: 4 ports detected
[ 2.196767] EXT4-fs (mmcblk0p1): recovery complete
[ 2.197883] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.199725] Rootfs mounted over mmcblk0p1
[ 2.202110] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.217453] Switching from initrd to actual rootfs
[ 2.217699] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.234539] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 2.234546] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.234550] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 2.234554] usb 2-1: Manufacturer: Generic
[ 2.237884] hub 2-1:1.0: USB hub found
[ 2.238656] hub 2-1:1.0: 4 ports detected
[ 2.241748] usb 1-2: usb_suspend_both: status 0
[ 2.241837] usb usb1: usb_suspend_both: status 0
[ 2.310047] systemd[1]: System time before build time, advancing clock.
[ 2.335565] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.346905] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.365513] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.366311] systemd[1]: Detected architecture arm64.
[ 2.388256] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 2.389701] usb 2-1: usb_suspend_both: status 0
[ 2.389863] usb usb2: usb_suspend_both: status 0
[ 2.397713] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.472160] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.472169] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.575040] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.575071] systemd[1]: Reached target Swap.
[ 2.575267] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.576847] systemd[1]: Created slice System Slice.
[ 2.577050] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.578877] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.579070] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.579196] systemd[1]: Listening on udev Kernel Socket.
[ 2.641332] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.785253] systemd-journald[1949]: Received request to flush runtime journal from PID 1
[ 2.815725] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.817727] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.923119] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.923125] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.923130] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.923134] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.923138] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.923159] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.923222] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.923382] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.923495] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.923518] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.923548] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.923568] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.923692] pci 0000:01:00.0: supports D1 D2
[ 2.923695] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.933760] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.933795] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.933799] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.933807] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.933825] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.933841] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.933849] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.933853] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.933859] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.934139] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.934143] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.934149] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.934249] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.934444] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.934460] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.958164] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.958234] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:e0:3c:8f from device tree
[ 2.958947] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.958964] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.267356] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.272006] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.272027] cpu-throttle-alert cooling device registered.
[ 3.272200] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.272215] gpu-throttle-alert cooling device registered.
[ 3.272375] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.272388] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.272402] hot-surface-alert cooling device registered.
[ 3.530817] using random self ethernet address
[ 3.535295] using random host ethernet address
[ 3.985720] tegra-xusb 70090000.xusb: entering ELPG
[ 3.986805] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 3.987040] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 3.988655] tegra-xusb 70090000.xusb: entering ELPG done
[ 4.004564] random: crng init done
[ 4.007969] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.303297] Mass Storage Function, version: 2009/09/11
[ 4.303303] LUN: removable file: (no medium)
[ 4.315534] using random self ethernet address
[ 4.320017] using random host ethernet address
[ 4.428341] rndis0: HOST MAC 82:c9:02:27:7c:84
[ 4.428814] rndis0: MAC 82:c9:02:27:7c:85
[ 4.429377] usb0: HOST MAC 82:c9:02:27:7c:86
[ 4.429409] usb0: MAC 82:c9:02:27:7c:87
[ 4.429430] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.430549] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.430568] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.430598] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.430948] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.430972] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.431643] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.431655] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.431993] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.449167] l4tbr0: port 1(rndis0) entered blocking state
[ 4.449172] l4tbr0: port 1(rndis0) entered disabled state
[ 4.450466] OS02C10 0-0036: probing v4l2 sensor
[ 4.450705] OS02C10 0-0036: tegracam sensor driver:OS02C10_v2.0.6
[ 4.456016] device rndis0 entered promiscuous mode
[ 4.457319] tegra-i2c 7000c000.i2c: no acknowledge from address 0x36
[ 4.462989] OS08A20 6-0036: probing v4l2 sensor
[ 4.463279] OS08A20 6-0036: tegracam sensor driver:OS08A20_v2.0.6
[ 4.464331] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.471778] l4tbr0: port 2(usb0) entered blocking state
[ 4.471780] l4tbr0: port 2(usb0) entered disabled state
[ 4.473336] device usb0 entered promiscuous mode
[ 4.474533] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x36
[ 4.474855] OS08A20 6-0036: OS08A20_fuse_id_setup: can not read fuse id
[ 4.474858] OS08A20 6-0036: Error -22 reading fuse id data
[ 4.474861] OS08A20 6-0036: board setup failed
[ 4.474911] OS08A20: probe of 6-0036 failed with error -22
[ 4.481871] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.558717] OS02C10 0-0036: OS02C10_fuse_id_setup: can not read fuse id
[ 4.570976] OS02C10 0-0036: Error -22 reading fuse id data
[ 4.581373] OS02C10 0-0036: board setup failed
[ 4.587399] OS02C10: probe of 0-0036 failed with error -22
[ 4.780849] zram: Added device: zram0
[ 4.785255] zram: Added device: zram1
[ 4.790258] zram: Added device: zram2
[ 4.797853] zram: Added device: zram3
[ 4.848666] zram0: detected capacity change from 0 to 519598080
[ 4.866735] Adding 507416k swap on /dev/zram0. Priority:5 extents:1 across:507416k SS
[ 4.879471] zram1: detected capacity change from 0 to 519598080
[ 4.913282] Adding 507416k swap on /dev/zram1. Priority:5 extents:1 across:507416k SS
[ 4.924793] zram2: detected capacity change from 0 to 519598080
[ 4.943388] Adding 507416k swap on /dev/zram2. Priority:5 extents:1 across:507416k SS
[ 4.951822] zram3: detected capacity change from 0 to 519598080
[ 4.964875] Adding 507416k swap on /dev/zram3. Priority:5 extents:1 across:507416k SS
[ 5.147339] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.149136] eth0: 0xffffff800abc8000, 48:b0:2d:e0:3c:8f, IRQ 407
[ 5.225579] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.274633] r8168: eth0: link up
[ 8.275195] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.908392] vdd-fan: disabling
[ 33.908437] vdd-usb-vbus: disabling
[ 33.908469] vdd-usb-vbus2: disabling
[ 33.908553] vddio-sdmmc-ap: disabling
[ 33.909261] vdd-3v3-sd: disabling
[ 33.909308] avdd-io-edp-1v05: disabling
[ 33.909341] vdd-usb-hub-en: disabling
I tried without success…
