I tried this, and it fixes the belly movements, but I am confused what part to keep visible… There are some many parts, some moving and some not.
I sent the scene for you as PM.
@esusantolim I hope you can find time to check my scene and guide me how to proceed further. This is a real paid project and customer is waiting.
Hi @pekka.varis ,
As mentioned before. try enable useMaxDistance on the prox deformer that affect the body.
In your scene these are the two Prox at the bottom of the list
Set both to active again (as you previously disabled one),
maxDistance to a value other than 0, like 0.1
useMaxDistance True
That should fix the issue
Hope it helps
Great!! this fixed the errors.
I now continue with the last video connecting to fullbody!
Breakthrough!
Still gotta work with teeths & eye movement. I take again the latest steps…
@esusantolim can you please check this out?
I am continuing my work form the point where I finish the “_004_charTransfer” ( refering to your video tutorial naming ) and then I save the file, do the fix with LazyGraph, continue with Attachnig Prims.
Then I do the “005_fixingReadUpdate” and this is were my results are a bit different. Please see my video:
In my case these:
move together.
In your “005_fixingReadUpdate” video at 4:22 they move correctly:
What can this be?
Can you see the reason from my workflow video above?
Pekka
The solution was simple!
I used the same fix method ( with correct settings ).
These all fixes stay ok after saving / reopening also, so these need to be done only one time :)
@esusantolim please can you check this out:
Everything is now correct except the left Eye is peeking out :/
Can you see from my video what it might be?
Pekka
@esusantolim
The LazyGraph fix did dot worked on this issue:
It is fixing the left eye popping out, but it also stopped the movement of that eye totally.
So I wait for your guidance.
@pekka.varis
Try fix this one
@esusantolim Thank you but this time the fix was not solving the problem.
I made a video for you to see my full workflow with the Camilla eyeballs:
If you have time, check it out - if there is any error I bet you spot it.
I have done it following your tutorial videos.
Here is the full Camilla CC4 / A2F fullbody motion workflow in one video, including the needed fixes if scene is saved at some point of the workflow.
Thank you very much @esusantolim for you help on this!!!
