1.What is the difference between NvBufferPayload_SurfArray and NvBufferPayload_MemHandle?
2.What is the difference between NvBufferLayout_Pitch and NvBufferLayout_BlockLinear?
3.I want to convert YUYV format data to GREY format. How should I configure these two variables?
4.Implementing YUV to gray8 conversion using the following code, the resulting image has issues. Can you please help identify the error? Thank you.
void es_yuyv_2_grey(unsigned char *p_img_in, int width, int height, unsigned char *p_img_out)
nv_buffer buff_yuyv_buff = {0};
nv_buffer * yuyv_buff = &buff_yuyv_buff;
NvBufferCreateParams input_params = {0};
input_params.payloadType = NvBufferPayload_SurfArray;
input_params.width = width;
input_params.height = height;
input_params.layout = NvBufferLayout_Pitch;
input_params.colorFormat = NvBufferColorFormat_YUYV;
input_params.nvbuf_tag = NvBufferTag_VIDEO_CONVERT;
if (-1 == NvBufferCreateEx(&yuyv_buff->dmabuff_fd, &input_params))
ERROR_RETURN_NULL("Failed to create NvBuffer");
if (-1 == NvBufferMemMap(yuyv_buff->dmabuff_fd, 0, NvBufferMem_Read_Write,
(void**)&yuyv_buff->start))
NvBufferDestroy(yuyv_buff->dmabuff_fd);
ERROR_RETURN_NULL("Failed to map buffer");
nv_buffer buff_grey_buff = {0};
nv_buffer * grey_buff = &buff_grey_buff;
input_params.colorFormat = NvBufferColorFormat_GRAY8;
if (-1 == NvBufferCreateEx(&grey_buff->dmabuff_fd, &input_params))
NvBufferMemUnMap(yuyv_buff->dmabuff_fd, 0, (void**)&yuyv_buff->start);
if (-1 == NvBufferMemMap(grey_buff->dmabuff_fd, 0, NvBufferMem_Read_Write,
(void**)&grey_buff->start))
NvBufferDestroy(grey_buff->dmabuff_fd);
NvBufferTransformParams transParams;
// Init the NvBufferTransformParams
memset(&transParams, 0, sizeof(transParams));
transParams.transform_flag = NVBUFFER_TRANSFORM_FILTER;
transParams.transform_filter = NvBufferTransform_Filter_Smart;
memcpy(yuyv_buff->start, p_img_in, width*height);
NvBufferMemSyncForDevice(yuyv_buff->dmabuff_fd, 0, (void**)&yuyv_buff->start);
// Convert the camera buffer from YUV422 to GRAY8
if (-1 == NvBufferTransform(yuyv_buff->dmabuff_fd, grey_buff->dmabuff_fd,
&transParams))
printf("Failed to convert the buffer\n");
memcpy(p_img_out, grey_buff->start, width*height);
NvBufferMemUnMap(grey_buff->dmabuff_fd, 0, (void**)&grey_buff->start);
