we have a MIPI-CSI capture device wich give us an AYUV image (Bits31-24 Alpha, Bits23-16 Y, Bits 15-8 U, Bits 7-0 V). We have been able to capture it and need to transform it into something nvv4l2h265enc can manage.
Is the layout of NvBufferColorFormat_YUV444 the same as what we are receiving? Can NvBufferTransform transform it into I420 or NV12?
We have tried adding GST_VIDEO_FORMAT_AYUV/NvBufferColorFormat_YUV444 to nvvidconv but calling NvBufferTransform results in:
Caught SIGSEGV
#0 0x0000007f9790fa04 in poll () from /lib/libc.so.6
#1 0x0000007f97a2d54c in ?? () from /usr/lib/libglib-2.0.so.0
#2 0x0000007f97a2d924 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#3 0x0000007f97bc3b0c in gst_bus_poll () from /usr/lib/libgstreamer-1.0.so.0
#4 0x000000559071ea08 in ?? ()
#5 0x000000559071d878 in ?? ()
#6 0x0000007f97872110 in __libc_start_main () from /lib/libc.so.6
#7 0x000000559071df18 in ?? ()
Spinning. Please run 'gdb gst-launch-1.0 6777' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Is this caused due to NvBufferTransform not being able to transform YUV422 to I420 nor NV12, or may be we are doing something wrong before calling NvBufferTransform?
transform_params.transform_flag = 0;
transform_params.transform_filter = NvBufferTransform_Filter_Nearest; // i think this doesn't care because transform_flag = 0
transform_params.transform_flip = NvBufferTransform_None; // i think this doesn't care because transform_flag = 0
transform_params.src_rect.top = 0
transform_params.src_rect.left = 0
transform_params.src_rect.width = 0
transform_params.src_rect.height = 0
transform_params.dst_rect.top
transform_params.dst_rect.left = 0
transform_params.dst_rect.width = 0
transform_params.dst_rect.height = 0
After looking at the examples of tegra_multimedia_api I think that NvBufferColorFormat_YUV444 is a planar format, with one buffer with the frame Y samples, anothe buffer with the frame U samples and one last buffer with the frame V samples. So, it seems that it’s not possible to do the conversion using NvBufferTransform.
For the moment we will use gstreamer’s videoconvert. But for the future I would like to know, Is nvarguscamerasrc able to convert from our 32bits-packed AYUV input to I420 or another format compatible with nvvidconv (maybe NV24 or RGB888)?
