It is clear from image that we have two extra tiny green square after transformation, does it need any extra settings for transformation to remove them?
Thanks so much.
We don’t see this kind of issue before. Would need your help to share a test sample, or a patch on our reference sample to replicate the issue. So that we can set up and check. OUr reference samples are in
Hi
Thanks so much for your attention. This is our code we want convert UYVY 1920*1080 CPU frame to NVMM I420 frame without using nvvidconv. We see these two green square.
GstFlowReturn onNewSampleFromSink(GstElement *elt, gpointer *This)
//initial setup phase
int dmabuf_fd;
int dst_fd;
//input frame color space is UYVY and 1920*1080 from v4l2src
NvBufferCreate(&dmabuf_fd, 1920, 1080, NvBufferLayout_Pitch, NvBufferColorFormat_UYVY);
NvBufferCreateParams outPut_params = {0};
NvBufferParams paramsOut;
NvBufferGetParams(dmabuf_fd,¶msOut);
outPut_params.payloadType = NvBufferPayload_SurfArray;
outPut_params.layout = NvBufferLayout_Pitch;
outPut_params.width = 1920;
outPut_params.height = 1080;
outPut_params.colorFormat = NvBufferColorFormat_YUV420;
outPut_params.nvbuf_tag = NvBufferTag_VIDEO_CONVERT;
//converted frame color space is I420 NVMM without cropping,
//scaling, flipping or any filter
NvBufferCreateEx(&dst_fd, &outPut_params);
// for each frmae
GstSample *sample;
GstBuffer *buffer;
GstElement *source;
GstFlowReturn ret;
/* get the sample from appsink */
sample = gst_app_sink_pull_sample(GST_APP_SINK (elt));
GstBuffer * buffer_sample = gst_sample_get_buffer (sample);
// GstBuffer * app_buffer = gst_buffer_copy (buffer_sample);
GstMapInfo map;
// /* Mapping a buffer can fail (non-writable) */
gst_buffer_map (buffer_sample, &map, GST_MAP_READ);
source = gst_bin_get_by_name (
GST_BIN (This->appSource),
"appSrc");
char *virtual_addr;
Raw2NvBuffer(map.data, 0, 1920, 1080, dmabuf_fd);
NvBufferGetParams(dmabuf_fd, ¶msOut);
outPut_params.colorFormat = NvBufferColorFormat_YVU420;
outPut_params.nvbuf_tag = NvBufferTag_NONE;
//NvBufferCreateEx(&dst_fd, &outPut_params);
NvBufferTransformParams transParams ={0};
memset(&transParams, 0, sizeof(transParams));
transParams.transform_flag = NVBUFFER_TRANSFORM_FLIP;
transParams.transform_filter = NvBufferTransform_Filter_Bilinear;
NvBufferTransform(dmabuf_fd , dst_fd, &transParams);
NvBufferParamsEx params = { 0, };
if (NvBufferGetParamsEx (dst_fd, ¶ms)) {
buffer = gst_buffer_new_wrapped(params.params.nv_buffer, params.params.nv_buffer_size);
g_signal_emit_by_name(GST_APP_SRC (source), "push-buffer", buffer, &ret);
