Nvvideoconvert gives error when input buffer is RGB, BGR or UYVP
• Hardware Platform (Jetson / GPU): Jetson AGX Xavier Dev
• DeepStream Version: 6.1.1
• JetPack Version (valid for Jetson only): 5.0.2
• TensorRT Version: 8.4
• Issue Type( questions, new requirements, bugs): bug
This pipeline gives error:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw, width=640, height=480, framerate=30/1" ! videoconvert ! "video/x-raw,format=(string)RGB" ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=(string)NV12" ! cam1.sink_0 nvstreammux name=cam1 width=1024 height = 1200 batch-size=1 ! nvvideoconvert ! videoconvert ! xvimagesink
The error: nvvideoconvert gstnvvideoconvert.c:3750:gst_nvvideoconvert_transform: buffer transform failed
Full output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstNvStreamMux:m.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1024, height=(int)1200, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert1.GstPad:src: caps = video/x-raw, width=(int)1024, height=(int)1200, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:src: caps = video/x-raw, width=(int)1024, height=(int)1200, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, block-linear=(boolean)false, format=(string)YV12
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, width=(int)1024, height=(int)1200, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, block-linear=(boolean)false, format=(string)YV12
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:sink: caps = video/x-raw, width=(int)1024, height=(int)1200, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1024, height=(int)1200, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false, batch-size=(int)1, num-surfaces-per-frame=(int)1
/GstPipeline:pipeline0/GstNvStreamMux:m.GstNvStreamPad:sink_0: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)30/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
0:00:02.740203784  6008 0xaaaabfaf85e0 ERROR         nvvideoconvert gstnvvideoconvert.c:3750:gst_nvvideoconvert_transform: buffer transform failed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
Execution ended after 0:00:01.864619813
Setting pipeline to NULL ...
Freeing pipeline ...
To fix the error, we need to change to colour format of the input buffer of nvvideoconvert. Here I use NV12, but it can be any format supported by nvvideoconvert and videoconvert other than RGB, BGR and UYVP:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw, width=640, height=480, framerate=30/1" ! videoconvert ! "video/x-raw,format=(string)NV12" ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=(string)NV12" ! cam1.sink_0 nvstreammux name=cam1 width=1024 height = 1200 batch-size=1 ! nvvideoconvert ! videoconvert ! xvimagesink
From the output of “gst-inspect-1.0 nvvideoconvert” you can see below format supported for video-raw:
(string)I420, (string)P010_10LE, (string)NV12, (string)BGRx, (string)RGBA, (string)GRAY8, (string)YUY2, (string)UYVY, (string)YVYU, (string)Y42B, (string)RGB, (string)BGR, (string)UYVP
As there is videoconvert in your pipeline, you can let videoconvert to connect with nvvideoconvert directly and let the elements negotiate the capacities, the capacities filter in between is not necessary.
@yingliu,
Thank you for the reply. I use v4l2src to reproduce the bug with any camera that support v4l2src, the capfilter added between videoconvert and nvvideoconvert is to demonstrate that nvvideoconvert gives error for some colour formats that it supports. My actual use case needs RGB as the colour format to nvvideoconvert. At the moment, I must use videoconvert just to convert from RGB to another colour format accepted by nvvideoconvert even though nvvideoconvert supports RGB directly. The post is to report a potential bug. Can you confirm if it’s indeed a bug or something else?
can you provide more logs? thanks, please do “export GST_DEBUG=5” first, then run again.
@fanzh,
Thank you for your reply. Here is the log files for these settings:
export GST_DEBUG=5
export GST_DEBUG_NO_COLOR=1
export GST_DEBUG_FILE=/tmp/log1.txt
Command that cause error (pipeline stopped due to error):
log1.txt (6.0 MB)
Command that ran normally (I closed the display window to stop the pipeline):
log2.txt (32.3 MB)
Hi @hyperlight , please set the compute-hw=1 para to nvvideoconvert with DS6.1.1 when you change RGB format to YUV format. Thanks
! nvvideoconvert compute-hw=1 !
