Gstreamer element nvvideoconvert gives wrong color output
Hi!
I use deepstream 6.0 on Tesla T4 (NV drivers 470.63.01).
I tried to process a JPEG image (to detect objects) and found that element Gst-nvvideoconvert causes change of color pallete.
For example:
gst-launch-1.0 -e filesrc location=./src_white_255.jpg ! jpegdec ! nvvideoconvert ! jpegenc ! filesink location=./dst_gray_235.jpg
If we use element Gst-videoconvert then there is no color change:
gst-launch-1.0 -e filesrc location=./src_white_255.jpg ! jpegdec ! videoconvert ! jpegenc ! filesink location=./dst_white_255.jpg
Could you prompt way how to get original color with using of nvvideoconvert?
The first pipeline does not work.
Got the following error:
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
nvbufsurface: NvBufSurfaceSysToHWCopy: failed in mem copy
nvbufsurface: NvBufSurfaceCopy: failed to copy
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.000262556
Setting pipeline to READY …
Cuda failure: status=700
nvbufsurface: Error(-1) in releasing cuda memory
Setting pipeline to NULL …
Freeing pipeline …
I can reproduce the problem with nvjpegdec + nvvidoconvert.
gst-launch-1.0 --gst-debug=jpegenc:5 -e filesrc location=./test.jpg ! nvjpegdec ! nvvideoconvert nvbuf-memory-type=3 ! 'video/x-raw,colorimetry=bt709' ! queue ! jpegenc ! filesink location=./dst_gray_235.jpg
We will investigate the issue.
What is the status of this issue?
We are experiencing the same problem. We discovered it, when upgrading from L4T 32.7.1 to L4T 35.2.1. We are recording from a camera and then converting the video stream from RGB to I420 using nvvideoconvert.
It has been fixed internally. Please wait for the future releases.
