I need to use multi-channel texture. In the documentation (https://developer.download.nvidia.cn/cg/tex3D.html), text3D supports the operation:
float4 tex3D(sampler3D samp, float3 s)
It returns a four channel value. However, I am not clear how to define the sampler3D correctly. Here are some fragments of what I did:
#include <cuda.h>
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include “cutil_math.h”
texture <float4, cudaTextureType3D, cudaReadModeElementType> samp;
global void readDataKernel(float *saver)
int xIdx = blockIdx.x * blockDim.x + threadIdx.x;
int yIdx = blockIdx.y * blockDim.y + threadIdx.y;
float3 pos = make_float3(posx, posy, pposz);
float4 val;
val = text3D(samp, pos); //FIXME
extern “C” void readData(cudaArray *d_arrayBuf, float *saver)
samp.addressMode[0] = cudaAddressModeBorder;
samp.addressMode[1] = cudaAddressModeBorder;
samp.filterMode = cudaFilterModeLinear;
samp.normalized = false;
cudaChannelFormateDesc channelDesc = cudaCreateChannelDesc(32, 32, 32, 32, cudaChannelFormatKindFloat);
//cudaChannelFormateDesc channelDesc = cudaCreateChannelDesc();
cudaMalloc3DArray(&d_arrayBuf, &channelDesc, make_cudaExtent(xNum, yNum, zNum));
cudaBindTextureToArray(samp, d_arrayBuf, channelDesc);
unsigned int blockSzX = 8;
unsigned int blockSzY = 8;
dim3 dGrid = {(xNum+blockSzX-1)/blockSzX, (yNum+blockSzY-1)/blockSzY, 1};
dim3 dBlock={blockSzX, blockSzY, 1};
readDataKernel<<<dGrid, dBlock>>>(saver);
cudaUnbindTexture(samp);
When I compile the above code, I got an error at the line of val = text3D(samp, pos):
“no instance of overloaded function “text3D” matches the argument list”.
How can I fix this problem? Anyone can help? Thanks!
