tex3d reads nothing....
I’m tring to read value from a 3d cudaArray which is bound to a texture reference.
but it seems tex3d doesn’t work at all.
I dont know the problem is whether i use tex3d incorrectly or the cudaArray is bound to texref wrongly…
all in one cu file
texture<float4, 3, cudaReadModeElementType> stateTex; // 3D texture
// at first i initialize the array, pitch, texref and bind the array to the texref.
extern "C" void cudoInitTexture(cudaPitchedPtr *pitch, cudaArray **array, float3 arraySize, GLuint *texObj, int glStage)
	*array = 0;
	// create the texture array
	cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float4>();
	cudaExtent volumeSize = make_cudaExtent(arraySize.x, arraySize.y, arraySize.z);
	CUDA_SAFE_CALL(cudaMalloc3DArray(array, &channelDesc, volumeSize) );
	// create memory using a cudaPitchedPtr
	cudaExtent pitchVolSize = make_cudaExtent(arraySize.x*sizeof(float4), arraySize.y, arraySize.z);
	CUDA_SAFE_CALL(cudaMalloc3D(pitch, pitchVolSize));
	glGenTextures(1, texObj);
	glActiveTexture(GL_TEXTURE0 + glStage);
	glBindTexture(GL_TEXTURE_2D_ARRAY, *texObj);
	glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
	glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
	glTexImage3D(GL_TEXTURE_2D_ARRAY, 0, GL_RGBA32F, arraySize.x, arraySize.y, arraySize.z, 0, GL_RGBA, GL_FLOAT, 0);
	glBindImageTextureEXT(glStage, *texObj, 0, true, 0,  GL_READ_WRITE, GL_RGBA32F);
	glBindTexture(GL_TEXTURE_2D_ARRAY, 0);
	stateTex.normalized = false;
	stateTex.filterMode = cudaFilterModePoint;
	stateTex.addressMode[0] = cudaAddressModeClamp;
	stateTex.addressMode[1] = cudaAddressModeClamp;
	stateTex.addressMode[2] = cudaAddressModeClamp;
	CUDA_SAFE_CALL(cudaBindTextureToArray(stateTex, *array, channelDesc));
	cutilCheckMsg( "cudaBindTextureToArray" );
// then I do the initialize for position of each particles of the object, and it works.
// the initial shape is rendered as expectable by openGL, which means array, pitch and gl interoperability work.
// then i use tex3d to read from the array via texref
__global__ void simulateExplicit(cudaPitchedPtr cpp, float2 clothSize, float clothWidthLength, float3 windForce, float3 displacement, float deltaTime)
	int x = threadIdx.x + blockIdx.x * blockDim.x;
	int y = threadIdx.y + blockIdx.y * blockDim.y;
	if(x >= clothSize.x || y >= clothSize.y)
		return;
	int index = x + y * clothSize.x;
        // in order to find out the reason, i commented all other simulation operations.
        // just read the value and store it again without any computation, so the object should remain the same shape,
        // but it just disappear immediately in like very very short time
	float4 parPosTmp = tex3D(stateTex, x, y, 0);
	((float4 *)cpp.ptr)[index] = parPosTmp;
The object’s shape should remain the same, but the whole object disappear, hence i guess the problem may be because I use tex3d or bind function incorrectly.
sadly, i have no idea why…
any can one help?
thanks alot!
waiting for help…
