How to use texture mem? The code from programming guide failed on my laptop
Is the texture available on nv device? how about on emulator?
my laptop does not have a nv device, so I use “nvcc -deviceemu xxx.cu”
my code is:
global void kernel(int*);
texture<int, 1> tex;
int main(void)
int x[4]={1,2,3,4}, y[4];
int *h_x=&x[0], *h_y=&y[0];
int *d_x, *d_y;
cudaMalloc((void**) &d_x, 4*sizeof(int));
cudaMalloc((void**) &d_y, 4*sizeof(int));
cudaArray* cu_array;
// Allocate array
cudaChannelFormatDesc description = cudaCreateChannelDesc<int>();
cudaMallocArray(&cu_array, &description, 4, 1);
// Copy image data to array
cudaMemcpy(cu_array, h_x, 4*sizeof(int), cudaMemcpyHostToDevice);
// Bind the array to the texture
cudaBindTextureToArray(tex, cu_array);
int dimBlock=4;
kernel<<< 1, dimBlock >>>(d_y);
cudaMemcpy(h_y, d_y, 4*sizeof(int), cudaMemcpyDeviceToHost);
int i;
printf("\nby gpu:\n");
for(i = 0; i < 4; i++)
	printf("%f ", h_y[i]);
printf("\n");
cudaUnbindTexture(tex);
//free(h_data); free(h_indices); free(h_x); free(h_y);
//cudaFree(d_data); cudaFree(d_indices); cudaFree(d_x); cudaFree(d_y);
return 0;
global void kernel(int* odata)
unsigned int x = threadIdx.x;
int c = tex1D(tex, x);
odata = c;
however, the output is 0 0 0 0. what i expect is 1 2 3 4
is here any error? but i can succeed compiling it.
You cannot copy data to or from array using cudaMemcpy.
