Hi all,
We tried to use ttyS2 as a UART connection port to communicate with fly control module, but we got some error message as below:
“ERROR: file descriptor /dev/ttyS2 is NOT a serial port”
My question is:
- is UART3 mounted as ttyS2 in default?
- if not, how can we mount it in kernel?
- is there any upper layer dev mounted for UART3?
I can’t answer, but what was it that said not a serial port? UART2 is connected to J3A2 header. I see this exists:
/sys/class/tty/ttyS2/device/driver/serial8250
What do you get from:
sudo setserial -a /dev/ttyS2
Hi Sir,
I’m not sure why we got the error message like that, we used the command you provided and got the following message.
“/dev/ttyS2, Line2, UART: unknown, Port: 0x0000, IRQ: 0
Baud_base: 0, close_delay: 50, divisor: 0
closing_wait: 3000
Flags: spd_normal”
it seems that ttyS2 even doesn’t have IRQ
I don’t know if IRQ is an issue. What command is producing the message about “is NOT a serial port”? Have you set up anything for ttyS2 in “/etc/init/”?
