I am trying to run four instances of ib_send_bw with UD between two computers with four MCX515A-CCAT NICs installed in each. I can run two instances. The third fails with an error.
Both computers are running RHEL 7.6. All 8 NICs are configured the same way.
On the server, in 3 separate windows I am running the following commands:
$ ib_send_bw -d mlx5_0 -c UD --report_gbits -i 1 -F --run_infinitely
$ ib_send_bw -d mlx5_1 -c UD -p 18520 --report_gbits -i 1 -F --run_infinitely
$ ib_send_bw -d mlx5_2 -c UD -p 18521 --report_gbits -i 1 -F --run_infinitely
On the client, the commands being run are:
$ ib_send_bw -d mlx5_0 -c UD -i 1 -F --report_gbits --run_infinitely 10.10.10.3
$ ib_send_bw -d mlx5_1 -c UD -i 1 -F -p 18520 --report_gbits --run_infinitely 10.10.10.4
$ ib_send_bw -d mlx5_2 -c UD -i 1 -F -p 18521 --report_gbits --run_infinitely 10.10.10.5
The first two instances run fine. The third instance fails with the following outputs.
server:
  • Waiting for client to connect… *
Send BW Test
Dual-port : OFF Device : mlx5_2
Number of qps : 1 Transport type : IB
Connection type : UD Using SRQ : OFF
RX depth : 1000
CQ Moderation : 100
Mtu : 4096[B]
Link type : Ethernet
GID index : 3
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
local address: LID 0000 QPN 0x010f PSN 0xc8809d
GID: 00:00:00:00:00:00:00:00:00:00:255:255:10:10:10:05
remote address: LID 0000 QPN 0x0111 PSN 0x7a219e
GID: 00:00:00:00:00:00:00:00:00:00:255:255:10:10:10:09
ethernet_read_keys: Couldn’t read remote address
Unable to read to socket/rdam_cm
Failed to exchange data between server and clients
Client:
Send BW Test
TX depth : 128
CQ Moderation : 100
Mtu : 4096[B]
GID index : 3
rdma_cm QPs : OFF
local address: LID 0000 QPN 0x0111 PSN 0x7a219e
remote address: LID 0000 QPN 0x010f PSN 0xc8809d
libibverbs: resolver: Neighbour doesn’t have a hw addr
libibverbs: resolver: Unspecific failurelibibverbs: Neigh resolution process failed
Failed to create AH for UD
Unable to Connect the HCA’s through the link
Any thoughts or suggestions would be most appreciated.
Thanks,
Terry
Please, configure your devices to have different IP subnets. 10.X.X.X, 11.X.X.X, 12.X.X.X and see if it helps.
Be sure to use same software stack - Mellanox OFED on both sides. If the issue happens with Inbox version of the driver, the question need to be addressed to RedHat. Mellanox support is limited to Mellanox OFED stack.
Hi Aleksey,
I am using Mellanox OFED on both sides
(OFED-4.7-1.0.0).
Changing the NICs to be on different subnets fixed
the problem. Now all four NIC pairs are running
ib_send_bw simultaneously. Thanks.
I have a follow up question: ib_send_bw reports
the bandwidth being achieved but it does not
report losses. Would you happen to know of a
test program that reports both band and any
packet/data losses that were encountered for RDMA UD?
Thanks again,
Terry
Nothing that comes to my mind. However, if using Mellanox hardware, you might be interested in looking into hardware counters and see if the amount of data sent is the same as received - https://community.mellanox.com/s/article/understanding-mlx5-linux-counters-and-status-parameters#jive_content_id_HW_Counters_RDMA_diagnostics
or maybe there are some drops/error/discards
