Please help me in this regard:
C:\Users\Armaan>pip install nvidia-modulus
Collecting nvidia-modulus
Using cached nvidia_modulus-0.8.0-py3-none-any.whl.metadata (21 kB)
Requirement already satisfied: torch>=2.0.0 in c:\users\armaan\appdata\local\programs\python\python310\lib\site-packages (from nvidia-modulus) (2.0.0+cu118)
Collecting numpy<1.25,>=1.22.4 (from nvidia-modulus)
Using cached numpy-1.24.4-cp310-cp310-win_amd64.whl.metadata (5.6 kB)
Collecting xarray>=2023.1.0 (from nvidia-modulus)
Using cached xarray-2024.10.0-py3-none-any.whl.metadata (11 kB)
Collecting zarr>=2.14.2 (from nvidia-modulus)
Using cached zarr-2.18.3-py3-none-any.whl.metadata (5.7 kB)
Requirement already satisfied: fsspec>=2023.1.0 in c:\users\armaan\appdata\local\programs\python\python310\lib\site-packages (from nvidia-modulus) (2024.6.0)
Collecting s3fs>=2023.5.0 (from nvidia-modulus)
Using cached s3fs-2024.10.0-py3-none-any.whl.metadata (1.7 kB)
Collecting nvidia-dali-cuda120>=1.35.0 (from nvidia-modulus)
Using cached nvidia_dali_cuda120-1.43.0.tar.gz (1.5 kB)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [53 lines of output]
INFO:nvidia-stub:Testing wheel nvidia_dali_cuda120-1.43.0-19497385-py3-none-manylinux2014_aarch64.whl against tag py3-none-manylinux2014_aarch64
INFO:nvidia-stub:Testing wheel nvidia_dali_cuda120-1.43.0-19497385-py3-none-manylinux2014_x86_64.whl against tag py3-none-manylinux2014_x86_64
File “C:\Users\Armaan\AppData\Local\Temp\pip-build-env-0ke9htuw\overlay\Lib\site-packages\nvidia_stub\wheel.py”, line 177, in download_wheel
return download_manual(wheel_directory, distribution, version)
File “C:\Users\Armaan\AppData\Local\Temp\pip-build-env-0ke9htuw\overlay\Lib\site-packages\nvidia_stub\wheel.py”, line 144, in download_manual
raise RuntimeError(f"Didn’t find wheel for {distribution} {version}“)
raise RuntimeError(f"Didn’t find wheel for {distribution} {version}”)
RuntimeError: Didn’t find wheel for nvidia-dali-cuda120 1.43.0
During handling of the above exception, another exception occurred:
File "C:\Users\Armaan\AppData\Local\Programs\Python\Python310\lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 353, in <module>
main()
File "C:\Users\Armaan\AppData\Local\Programs\Python\Python310\lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "C:\Users\Armaan\AppData\Local\Programs\Python\Python310\lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 152, in prepare_metadata_for_build_wheel
whl_basename = backend.build_wheel(metadata_directory, config_settings)
File "C:\Users\Armaan\AppData\Local\Temp\pip-build-env-0ke9htuw\overlay\Lib\site-packages\nvidia_stub\buildapi.py", line 29, in build_wheel
return download_wheel(pathlib.Path(wheel_directory), config_settings)
File "C:\Users\Armaan\AppData\Local\Temp\pip-build-env-0ke9htuw\overlay\Lib\site-packages\nvidia_stub\wheel.py", line 179, in download_wheel
report_install_failure(distribution, version, exception_context)
File "C:\Users\Armaan\AppData\Local\Temp\pip-build-env-0ke9htuw\overlay\Lib\site-packages\nvidia_stub\error.py", line 63, in report_install_failure
raise InstallFailedError(
nvidia_stub.error.InstallFailedError:
The installation of nvidia-dali-cuda120 for version 1.43.0 failed.
This is a special placeholder package which downloads a real wheel package
from https://pypi.nvidia.com. If https://pypi.nvidia.com is not reachable, we
cannot download the real wheel file to install.
You might try installing this package via
$ pip install --extra-index-url https://pypi.nvidia.com nvidia-dali-cuda120
Here is some debug information about your platform to include in any bug
report:
Python Version: CPython 3.10.11
Operating System: Windows 10
CPU Architecture: AMD64
Driver Version: 555.99
CUDA Version: 12.5
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
I also tried pip install --extra-index-url https://pypi.nvidia.com nvidia-dali-cuda120 but couldn’t able to install too.
