pip install isaacsim==4.0.0.0 --extra-index-url https://pypi.nvidia.com
Looking in indexes: Simple index, https://pypi.nvidia.com
Collecting isaacsim==4.0.0.0
Using cached isaacsim-4.0.0.0.tar.gz (761 bytes)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [51 lines of output]
File “/tmp/pip-build-env-0y0zlog0/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py”, line 147, in download_wheel
return download_manual(wheel_directory, distribution, version)
File “/tmp/pip-build-env-0y0zlog0/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py”, line 114, in download_manual
raise RuntimeError(f"Didn’t find wheel for {distribution} {version}“)
raise RuntimeError(f"Didn’t find wheel for {distribution} {version}”)
RuntimeError: Didn’t find wheel for isaacsim 4.0.0.0
During handling of the above exception, another exception occurred:
File "/home/biorobotics/miniconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/home/biorobotics/miniconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/biorobotics/miniconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel
whl_basename = backend.build_wheel(metadata_directory, config_settings)
File "/tmp/pip-build-env-0y0zlog0/overlay/lib/python3.10/site-packages/nvidia_stub/buildapi.py", line 29, in build_wheel
return download_wheel(pathlib.Path(wheel_directory), config_settings)
File "/tmp/pip-build-env-0y0zlog0/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 149, in download_wheel
report_install_failure(distribution, version, exception_context)
File "/tmp/pip-build-env-0y0zlog0/overlay/lib/python3.10/site-packages/nvidia_stub/error.py", line 63, in report_install_failure
raise InstallFailedError(
nvidia_stub.error.InstallFailedError:
The installation of isaacsim for version 4.0.0.0 failed.
This is a special placeholder package which downloads a real wheel package
from https://pypi.nvidia.com. If https://pypi.nvidia.com is not reachable, we
cannot download the real wheel file to install.
You might try installing this package via
$ pip install --extra-index-url https://pypi.nvidia.com isaacsim
Here is some debug information about your platform to include in any bug
report:
Python Version: CPython 3.10.14
Operating System: Linux 5.15.0-107-generic
CPU Architecture: x86_64
Driver Version: 535.171
CUDA Version: 12.2
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
