Isaac Sim Version
[-] 4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
[-] Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX4090
- Driver Version: 565.77
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
When I install the isaacsim in anconda with pip ,I can’t install it successfully.
Steps to Reproduce
- pip install isaacsim==4.2.0.2 --extra-index-url https://pypi.nvidia.com
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Looking in indexes: https://pypi.org/simple, https://pypi.nvidia.com
Collecting isaacsim==4.2.0.2
Using cached isaacsim-4.2.0.2.tar.gz (886 bytes)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [53 lines of output]
INFO:nvidia-stub:Testing wheel isaacsim-4.2.0.2-cp310-none-manylinux_2_34_x86_64.whl against tag cp310-none-manylinux_2_34_x86_64
INFO:nvidia-stub:Testing wheel isaacsim-4.2.0.2-cp310-none-win_amd64.whl against tag cp310-none-win_amd64
File "/tmp/pip-build-env-1w0qe4f7/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 177, in download_wheel
return download_manual(wheel_directory, distribution, version)
File "/tmp/pip-build-env-1w0qe4f7/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 144, in download_manual
raise RuntimeError(f"Didn't find wheel for {distribution} {version}")
RuntimeError: Didn't find wheel for isaacsim 4.2.0.2
During handling of the above exception, another exception occurred:
File "/home/fiveages/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/home/fiveages/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/fiveages/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel
whl_basename = backend.build_wheel(metadata_directory, config_settings)
File "/tmp/pip-build-env-1w0qe4f7/overlay/lib/python3.10/site-packages/nvidia_stub/buildapi.py", line 29, in build_wheel
return download_wheel(pathlib.Path(wheel_directory), config_settings)
File "/tmp/pip-build-env-1w0qe4f7/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 179, in download_wheel
report_install_failure(distribution, version, exception_context)
File "/tmp/pip-build-env-1w0qe4f7/overlay/lib/python3.10/site-packages/nvidia_stub/error.py", line 63, in report_install_failure
raise InstallFailedError(
nvidia_stub.error.InstallFailedError:
The installation of isaacsim for version 4.2.0.2 failed.
This is a special placeholder package which downloads a real wheel package
from https://pypi.nvidia.com. If https://pypi.nvidia.com is not reachable, we
cannot download the real wheel file to install.
You might try installing this package via
$ pip install --extra-index-url https://pypi.nvidia.com isaacsim
Here is some debug information about your platform to include in any bug
report:
Python Version: CPython 3.10.16
Operating System: Linux 5.15.0-125-generic
CPU Architecture: x86_64
CUDA Version: 12.7
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
