Isaac Sim installation error
Hi,when I installed Isaac Sim,this error occur
Error occurred during installation of Isaac Sim: Command failed: "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/omni.isaac.sim.post.install.sh"
UsdE57FileFormat
OmniAssetFileFormat
2022-06-06 13:02:58 [42,429ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
2022-06-06 13:02:58 [42,485ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
WARNING: You are using pip version 20.1.1; however, version 22.1.2 is available.
You should consider upgrading via the '/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/bin/python3 -m pip install --upgrade pip' command.
OmniAssetFileFormat
2022-06-06 13:03:11 [9,411ms] [Error] [rtx.neuraylib.plugin] [DYNLIB:IO]   0.1   DYNLIB io   error: /home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/bin/libs/iray/libnvindex.so: cannot open shared object file: No such file or directory
2022-06-06 13:03:11 [9,411ms] [Error] [rtx.neuraylib.plugin] [INDEX:MAIN]   0.1   INDEX  main error: Failed to load /home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/bin/libs/iray/libnvindex.so
2022-06-06 13:07:34 [273,030ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
2022-06-06 13:07:34 [273,087ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 3 or descriptorSetLayouts: 3 is leaking memory. Missing call to destroyResourceBindingSignature()
ERROR: Exception:
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 438, in _error_catcher
    yield
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 519, in read
    data = self._fp.read(amt) if not fp_closed else b""
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/cachecontrol/filewrapper.py", line 62, in read
    data = self.__fp.read(amt)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/http/client.py", line 465, in read
    n = self.readinto(b)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/http/client.py", line 509, in readinto
    n = self.fp.readinto(b)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/socket.py", line 589, in readinto
    return self._sock.recv_into(b)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/ssl.py", line 1071, in recv_into
    return self.read(nbytes, buffer)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/ssl.py", line 929, in read
    return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 173, in _main
    status = self.run(options, args)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/cli/req_command.py", line 203, in wrapper
    return func(self, options, args)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 316, in run
    reqs, check_supported_wheels=not options.target_dir
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 95, in resolve
    collected.requirements, max_rounds=try_to_avoid_resolution_too_deep
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 472, in resolve
    state = resolution.resolve(requirements, max_rounds=max_rounds)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 366, in resolve
    failure_causes = self._attempt_to_pin_criterion(name)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 212, in _attempt_to_pin_criterion
    criteria = self._get_updated_criteria(candidate)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 203, in _get_updated_criteria
    self._add_to_criteria(criteria, requirement, parent=candidate)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 172, in _add_to_criteria
    if not criterion.candidates:
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/resolvelib/structs.py", line 151, in __bool__
    return bool(self._sequence)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 140, in __bool__
    return any(self)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 128, in <genexpr>
    return (c for c in iterator if id(c) not in self._incompatible_ids)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 32, in _iter_built
    candidate = func()
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 209, in _make_candidate_from_link
    version=version,
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 301, in __init__
    version=version,
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 156, in __init__
    self.dist = self._prepare()
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 227, in _prepare
    dist = self._prepare_distribution()
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 306, in _prepare_distribution
    self._ireq, parallel_builds=True
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 508, in prepare_linked_requirement
    return self._prepare_linked_requirement(req, parallel_builds)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 552, in _prepare_linked_requirement
    self.download_dir, hashes
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 243, in unpack_url
    hashes=hashes,
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 102, in get_http_url
    from_path, content_type = download(link, temp_dir.path)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/network/download.py", line 145, in __call__
    for chunk in chunks:
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/cli/progress_bars.py", line 144, in iter
    for x in it:
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_internal/network/utils.py", line 87, in response_chunks
    decode_content=False,
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 576, in stream
    data = self.read(amt=amt, decode_content=decode_content)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 541, in read
    raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/contextlib.py", line 130, in __exit__
    self.gen.throw(type, value, traceback)
  File "/home/qiao/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 443, in _error_catcher
    raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
WARNING: You are using pip version 21.2.1+nv1; however, version 22.1.2 is available.
I use Ubuntu20.04,RTX 2080Ti
Hi, do Create install and launch sucessfully?
Please share the output of nvidia-smi.
No,can’t install Isaac Sim
| NVIDIA-SMI 470.129.06 Driver Version: 470.129.06 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:17:00.0 On | N/A |
| 18% 40C P8 9W / 250W | 357MiB / 11011MiB | 1% Default |
| | | N/A |
| 1 NVIDIA GeForce … Off | 00000000:D5:00.0 Off | N/A |
| 18% 33C P8 19W / 250W | 6MiB / 11019MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1463 G /usr/lib/xorg/Xorg 176MiB |
| 0 N/A N/A 1732 G /usr/bin/gnome-shell 38MiB |
| 0 N/A N/A 2369 G …nlogin/bin/sunloginclient 7MiB |
| 0 N/A N/A 2405 G /usr/lib/firefox/firefox 131MiB |
| 1 N/A N/A 1463 G /usr/lib/xorg/Xorg 4MiB |
And I tried docker but still occur an error:Error response from daemon: could not select device driver “” with capabilities: [[gpu]].
Try clearing the cache folder at
~/cache/ov/Kit
Then reboot and try installing again.
Ok,it works.Now I can install it,thanks!
