Произошла ошибка во время установки Isaac Sim: Command failed: "/media/evheniy/ssd/omniverse/lib/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh"
2022-04-01 21:40:26 [30,051ms] [Error] [rtx.postprocessing.plugin] createDLSSContext error: unable to initialize context. Optional DLSS feature is disabled.
2022-04-01 21:40:30 [33,814ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2022-04-01 21:40:30 [33,817ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2022-04-01 21:40:30 [33,825ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__sigaction
/media/evheniy/ssd/omniverse/lib/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh: строка 10: 14385 Ошибка сегментирования (стек памяти сброшен на диск) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
I can`t understand what is problem? driver 510. RTX3060. Ryzen7 1700x. 32GB RAM. Ubuntu 22.04
