安装 Isaac Sim 时出错:Command failed: “/data/omniverse_pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh”
2022-04-16 09:46:42 [5,003ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2022-04-16 09:46:42 [5,004ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::)(unsigned int, int, carb::cpp20::latch), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2022-04-16 09:46:42 [5,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
/data/omniverse_pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh:行 10: 32820 段错误 (核心已转储) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
os is ubuntu 20.04
cpu is 12thi7
gpu is 3060ti
