I have installed pytorch v 1.3.0 , but import torch is failing
I have installed pytorch 1.3.0 on Jetson Nano. But import torch is failing.
Error message:-
File “”, line 1, in
ModuleNotFoundError: No module named ‘torch’
Jetson SDK version is 4.3.
What could be wrong? any dependent packages required?
Regards,
Shankar
Can you please provide suggestions on this.
I did go through some of the related posts and tried them…like installing using Cuda, installing pillow 6.2.2, trying to install with different versions of torch and torchvision. But nothing worked for me.
Regards,
Shankar
THe instructions in the below link helped and I was able to install pytorch and torchvision.
https://devtalk.nvidia.com/default/topic/1049071/pytorch-for-jetson-nano-version-1-3-0-now-available/
Thank you.
