More Informantion :
Server-01:~# modinfo mlx5_core
filename: /lib/modules/5.4.0-84-generic/updates/dkms/mlx5_core.ko
alias: auxiliary:mlx5_core.eth-rep
version: 5.4-1.0.3
license: Dual BSD/GPL
description: Mellanox 5th generation network adapters (ConnectX series) core driver
author: Eli Cohen eli@mellanox.com
srcversion: 7B67674E4C53E7F9FEBDFFF
alias: pci:v000015B3d0000A2DCsvsdbcsci*
alias: pci:v000015B3d0000A2D6svsdbcsci*
alias: pci:v000015B3d0000A2D3svsdbcsci*
alias: pci:v000015B3d0000A2D2svsdbcsci*
alias: pci:v000015B3d00001021svsdbcsci*
alias: pci:v000015B3d0000101Fsvsdbcsci*
alias: pci:v000015B3d0000101Esvsdbcsci*
alias: pci:v000015B3d0000101Dsvsdbcsci*
alias: pci:v000015B3d0000101Csvsdbcsci*
alias: pci:v000015B3d0000101Bsvsdbcsci*
alias: pci:v000015B3d0000101Asvsdbcsci*
alias: pci:v000015B3d00001019svsdbcsci*
alias: pci:v000015B3d00001018svsdbcsci*
alias: pci:v000015B3d00001017svsdbcsci*
alias: pci:v000015B3d00001016svsdbcsci*
alias: pci:v000015B3d00001015svsdbcsci*
alias: pci:v000015B3d00001014svsdbcsci*
alias: pci:v000015B3d00001013svsdbcsci*
depends: mlx_compat,tls,auxiliary,mlxdevm,pci-hyperv-intf,mlxfw,psample
retpoline: Y
vermagic: 5.4.0-84-generic SMP mod_unload modversions
parm: guids:charp
parm: node_guid:guids configuration. This module parameter will be obsolete!
parm: num_of_groups:Eswitch offloads number of big groups in FDB table. Valid range 1 - 1024. Default 15 (uint)
parm: debug_mask:debug mask: 1 = dump cmd data, 2 = dump cmd exec time, 3 = both. Default=0 (uint)
parm: prof_sel:profile selector. Valid range 0 - 3 (uint)
parm: probe_vf:probe VFs or not, 0 = not probe, 1 = probe. Default = 1 (bool)
Server-01:~# uname -r
5.4.0-84-generic
Server-01:~# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 43 bits physical, 48 bits virtual
CPU(s): 192
On-line CPU(s) list: 0-191
Thread(s) per core: 2
Core(s) per socket: 48
Socket(s): 2
NUMA node(s): 2
Vendor ID: AuthenticAMD
CPU family: 23
Model: 49
Model name: AMD EPYC 7642 48-Core Processor
Stepping: 0
Frequency boost: enabled
CPU MHz: 1499.440
CPU max MHz: 2300.0000
CPU min MHz: 1500.0000
BogoMIPS: 4599.98
Virtualization: AMD-V
L1d cache: 3 MiB
L1i cache: 3 MiB
L2 cache: 48 MiB
L3 cache: 512 MiB
NUMA node0 CPU(s): 0-47,96-143
NUMA node1 CPU(s): 48-95,144-191
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Full AMD retpoline, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nop
l nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_leg
acy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate sme ssbd mba sev ibrs
ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm
_local clzero irperf xsaveerptr wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif
umip rdpid overflow_recov succor smca
