i am using the below command
./tao-converter -k nvidia_tlt -p Input,1x3x384x1248,8x3x384x1248,16x3x384x1248 -d 3,384,1248 -o BatchedNMS -e trt.engine -m 1 -t fp16 -i nchw /home/ubuntu/PoC/model/VehicleModel/yolov4_resnet18_epoch_050.etlt
im getting the below error
[ERROR] UffParser: Unsupported number of graph 0
[ERROR] Failed to parse the model, please check the encoding key to make sure it's correct
[ERROR] Network must have at least one output
[ERROR] Network validation failed.
[ERROR] Unable to create engine
Morganh
September 28, 2021, 7:23am
3
Is this yolov4_resnet18_epoch_050.etlt trained by yourself? Is the key correct ?
my colleague had trained it . we usually use default key nvidia_tlt , i think the KEY is correct
Morganh
September 28, 2021, 7:27am
5
Could you please compare the another forum topic created by you?
im trying to create engine file with the below command
./tao-converter -k nvidia_tlt -p Input,1x3x800x1376,8x3x800x1376,16x3x800x1376 -d 3,384,384 -o BatchedNMS -e trt.engine -m 1 -t fp16 -i nchw /home/ubuntu/PoC/model/yolov4_resnet18_epoch_050.etlt
And i get the below error . Kindly help
[WARNI…
You can run it successfully.
that was different etlt model , will cross check and get back to you
i was able to fix it .etlt File name issue was wrong
