Hi
Like in the picture below, I want to export the result of event view for only nvtx in .csv file.
And
I tried ‘nsys stats’ as follows, but there was an error.
nsys stats --report nvtxppsum --format csv,column --output .,- report.qdrep
Also, I don’t know if it’s the result I wanted.
What should I do?
There is currently no way to export data from just what is currently showing in the events pane. There have been feature requests for it, and I expect we will have that in the next few releases.
As for “nsys stats” not working, I think you have an error in your command line. Since you only want one report in one format, you should be able to just use:
nsys stats --report nvtxppsum --format csv report.qdrep
