I installed tensorflow successfully but its getting accessed…
Following is the error that I am getting when I tried to check the Import of Tensorflow…
python2
Python 2.7.17 (default, Feb 27 2021, 15:10:58)
[GCC 7.5.0] on linux2
Type “help”, “copyright”, “credits” or “license” for more information.
import tensorflow as tf
File “”, line 1, in
File “/usr/local/lib/python2.7/dist-packages/tensorflow/init.py”, line 22, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/init.py”, line 49, in
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(’_pywrap_tensorflow_internal’, fp, pathname, description)
ImportError: libcublas.so.9.0: cannot open shared object file: No such file or directory
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/install_sources#common_installation_problems
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
[2]+ Stopped python2
(yolov4-object-detection) computer@computer-desktop:~$
