Hello!
I have been stuck with the installation of Tensforflow-gpu on Jetson TX2 GPU for quite sometime. I installed it using: pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp33 tensorflow-gpu (SOURCE: https://docs.nvidia.com/deeplearning/frameworks/install-tf-jetsontx2/index.html)
It says that it has installed successfuly however, when i try to import it, it gives the error: “Failed to load the native TensorFlow runtime”
The stack trace of the error message is as under:
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(‘_pywrap_tensorflow_internal’, fp, pathname, description)
File “/usr/lib/python3.5/imp.py”, line 242, in load_module
return load_dynamic(name, filename, file)
File “/usr/lib/python3.5/imp.py”, line 342, in load_dynamic
return _load(spec)
ImportError: libcublas.so.9.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/init.py”, line 22, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/python/init.py”, line 49, in
File “/home/nvidia/.local/lib/python3.5/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
Failed to load the native TensorFlow runtime.
