I already flash JetPack4.1.1 DP and nstall HDF5 as required by TensorFlow:
apt-get install libhdf5-serial-dev hdf5-tools
and i set
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64
export PATH=$PATH:/usr/local/cuda-10.0/bin
export CUDA_HOME=$CUDA_HOME:/usr/local/cuda-10.0
But it still has error message.
nvidia@jetson-0423618000766:~$ python
Python 2.7.15rc1 (default, Nov 12 2018, 14:31:15)
[GCC 7.3.0] on linux2
Type “help”, “copyright”, “credits” or “license” for more information.
import tensorflow
File “”, line 1, in
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/init.py”, line 24, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/python/init.py”, line 49, in
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/home/nvidia/.local/lib/python2.7/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(‘_pywrap_tensorflow_internal’, fp, pathname, description)
ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
Failed to load the native TensorFlow runtime.
See Создание и установка сообщений об ошибках | TensorFlow
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
