Hi there,
I have installed Cuda and cudnn on Ubuntu 18.04 and it seems to be installed OK:
user:~$ nvcc -V
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Fri_Feb__8_19:08:17_PST_2019
Cuda compilation tools, release 10.1, V10.1.105
user:~$ nvidia-smi
Mon Mar 18 14:36:47 2019
| NVIDIA-SMI 418.43 Driver Version: 418.43 CUDA Version: 10.1 |
| 0 Quadro K5200 Off | 00000000:03:00.0 On | Off |
| 26% 39C P8 14W / 150W | 225MiB / 8118MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1538 G /usr/lib/xorg/Xorg 32MiB |
| 0 1583 G /usr/bin/gnome-shell 5MiB |
| 0 3008 G /usr/lib/xorg/Xorg 100MiB |
| 0 3120 G /usr/bin/gnome-shell 82MiB |
However, when I try to import tensorflow GPU I get import error for libcublas.so.10.0:
$ python3
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow as tf
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 58, in <module>
from tensorflow.python.pywrap_tensorflow_internal import *
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 28, in <module>
_pywrap_tensorflow_internal = swig_import_helper()
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 24, in swig_import_helper
_mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
File "/usr/lib/python3.6/imp.py", line 243, in load_module
return load_dynamic(name, filename, file)
File "/usr/lib/python3.6/imp.py", line 343, in load_dynamic
return _load(spec)
ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/__init__.py", line 24, in <module>
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/__init__.py", line 49, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 74, in <module>
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
What do I need to install to fix this problem? Is there something missing?
Amin
