libcublas.so.10.0 cannot be found when I import tensorflow. THe problem is that on the specified path /usr/local/cuda-10.0/lib64 it exists such a file. I think I have set the environmental variables correctly.
ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
Any ideas?
I am sorry please delete the post. It is posted on the wrong thread
You have to make sure it is correct, reviewing the installation guide: https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
If the program can’t find it, then there is still a problem with paths. In the same terminal you are compiling/running the program, do a “env | sort” and check that LD_LIBRARY_PATH currently points to the proper directory.
You can also create an empty program, link with -lcufft and see if it also complains when you run it.
I tried the env|sort and it points to the correct directory. I cannot understand what is wrong
