libcublas.so.9.0 cannot be found when importing tensorflow
I am installing cuda 9.0 and the latest Tensorflow 1.8. The error message goes:
ImportError: libcublas.so.9.0: cannot open shared object file: No such file or directory
Besides, I cannt search libcublas.so.9.0 under /usr/local directory. I am not sure whether cuda9.0 is properly installed. The nvcc --version yields the cuda version to be 9.0.
Any solutions?
You might want to make sure that the LD_LIBRARY_PATH environment variable is properly set:
[url]https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#mandatory-post[/url]
Yes, I can be sure. The point is, there is no such file “libcublas.so.9.0” in lib or lib64 (but only libcublas.so).
It may be a broken install then.
Usually there is a file like:
/usr/local/cuda/lib64/libcublas.so.9.0
Yes, it should be the problem. What is your suggestion for this problem? I followed exactly step-by-step tutorial in Nvidia website. BTW, I am using centOS 7 system.
The problem has been solved. Here is my solution:
  1. In order to upgrade to cuda-9.0, a compatible nvidia driver (384.xxx) is required. Check here ubuntu - What is the correct version of CUDA for my nvidia driver? - Stack Overflow
  2. To install cuda9.0 toolkit in CentOS system, it would be better to use runfile (local) than rpm.
