when i import tensorflow as tf: the following error message shows.
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(‘_pywrap_tensorflow_internal’, fp, pathname, description)
File “/home/shezan/venv/lib/python3.6/imp.py”, line 243, in load_module
return load_dynamic(name, filename, file)
File “/home/shezan/venv/lib/python3.6/imp.py”, line 343, in load_dynamic
return _load(spec)
ImportError: libcublas.so.9.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/init.py”, line 22, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/python/init.py”, line 49, in
File “/home/shezan/venv/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
Failed to load the native TensorFlow runtime.
See Build from source | TensorFlow
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
I have appended the following lines in the bashrc
export PATH=/usr/local/cuda-10.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64
${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
export CUDA_VISIBLE_DEVICES=0
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/extras/CUPTI/lib64
What have i done wrong?
