ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
I am trying to get tensorflow running on my Jetson Nano, but I don’t seem to find the error.
When importing tensorflow in python3 I get the following message:
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(‘_pywrap_tensorflow_internal’, fp, pathname, description)
File “/usr/lib/python3.6/imp.py”, line 243, in load_module
return load_dynamic(name, filename, file)
File “/usr/lib/python3.6/imp.py”, line 343, in load_dynamic
return _load(spec)
During handling of the above exception, another exception occurred:
File “try.py”, line 5, in
from tensorflow.keras.preprocessing.image import ImageDataGenerator
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/init.py”, line 24, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/python/init.py”, line 49, in
File “/home/nvidia/.local/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
Failed to load the native TensorFlow runtime.
See Build and install error messages  |  TensorFlow
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
My PATH is : /home/nvidia/usr/local/cuda-10.0/bin:/usr/local/cuda-10.0/bin:/home/nvidia/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
and my LD_LIBRARY_PATH: /usr/local/cuda-10.0/lib64
my tensorflow version and I’m using the newest Jetpack:
tensorboard 2.5.0
tensorboard-data-server 0.6.0
tensorboard-plugin-wit 1.8.0
tensorflow 2.4.0+nv21.3
tensorflow-estimator 2.4.0
tensorflow-gpu 1.13.1+nv19.3
If you need any more information feel free to ask. The answer to this questions might also be in some other post, but I wasn’t able to find it.
Thank you in advance.
