Hi
I have pull nvcr.io/nvidia/tensorflow:18.10-py3
docker pull nvcr.io/nvidia/tensorflow:18.10-py3
and get into this container:
docker run --rm -it nvcr.io/nvidia/tensorflow:18.10-py3
then test:
root@4f62d2cf34d1:/workspace# python
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow
error occured:
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 58, in <module>
from tensorflow.python.pywrap_tensorflow_internal import *
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 28, in <module>
_pywrap_tensorflow_internal = swig_import_helper()
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 24, in swig_import_helper
_mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
File "/usr/lib/python3.5/imp.py", line 242, in load_module
return load_dynamic(name, filename, file)
File "/usr/lib/python3.5/imp.py", line 342, in load_dynamic
return _load(spec)
ImportError: libcuda.so.1: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.5/dist-packages/tensorflow/__init__.py", line 22, in <module>
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/__init__.py", line 49, in <module>
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 74, in <module>
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/install_sources#common_installation_problems
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
why?
