Trying to convert kitti dataset to tfrecords.
command used:
!tlt-dataset-convert -d spec_files/convert.txt -o /tf_records
or
!tlt-dataset-convert -d /workspace/spec_files/convert.txt -o /workspace/tf_records/
and many other path combinations.
The spec_file being used:
kitti_config {
root_directory_path: "/workspace/dataset/KITTI_original/training"
image_dir_name: "image_2"
label_dir_name: "label_2"
image_extension: ".png"
partition_mode: "random"
num_partitions:2
val_split: 15
num_shards: 10
image_directory_path: "/workspace/dataset/KITTI_original/training"
Error:
File "/usr/local/bin/tlt-dataset-convert", line 6, in <module>
from iva.detectnet_v2.scripts.dataset_convert import main
File "./detectnet_v2/scripts/dataset_convert.py", line 14, in <module>
File "./detectnet_v2/dataio/build_converter.py", line 13, in <module>
File "./detectnet_v2/dataio/kitti_converter_lib.py", line 16, in <module>
File "/usr/local/lib/python2.7/dist-packages/tensorflow/__init__.py", line 24, in <module>
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/__init__.py", line 49, in <module>
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 74, in <module>
raise ImportError(msg)
ImportError: Traceback (most recent call last):
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 58, in <module>
from tensorflow.python.pywrap_tensorflow_internal import *
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 28, in <module>
_pywrap_tensorflow_internal = swig_import_helper()
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 24, in swig_import_helper
_mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
ImportError: libcuda.so.1: cannot open shared object file: No such file or directory
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/errors
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
trying to follow this notebook, https://github.com/NVIDIA-AI-IOT/tlt-iva-examples/blob/master/TLT_notebook.ipynb
kindly look into it.
